rabsusa »
https://forums.nicoclub.com/rabsusa-u135294.html
Fri May 24, 2013 4:13 pm
Greetings all,
I had to replace coolant in both Q's and the constant removal of coolant filler cap for checking & rechecking made them fail - they were probably on their way out anyway hence the failure....
infinitiguy kindly helped me out with the part numbers for replacement....
Prod.M/Y:1291- 21430-1P105-
Prod.M/Y:0889-0790 and Prod.M/Y:0790-1291 21430-60U00-
However, i wanted to source 4 caps - two which i needed, 2 for spare & one for my brothers car - adds up @$16 each!
Thru some research & trial & error, I found stant cap part number 10264 - can be had for 3-6 bucks at your local aftermarket shop. I fitted to my run around 158k beast (i don't care a damn abt it & flogg the crap out of it)- ambient temps were in the 90;s all week, AC pushing out out 50 degree air, no leaks. Coolant level is stable & exactly where i filled too in expansion bottle. Temp gauge exactly where it was before (actually angle looks lower as car now has coolant not water)Maybe that's physiological as i actually did something on car - one board member notices her Q runs faster after oil change LOL
Orig cap would start leaking as soon as car ran up to temp - here within 3- 5 mins as its so hot,,,,
~ just a helper for those of you running on a budget - for those of you officunardos running trailer/garage queens who wont even consider an aftermarket part on their car or taking it on a shopping trip to walmart please don't kill me with your responses of false wisdom/economys
cheers Rob
