At once I will tell - English at me not really good, but I will try to explain as to convert on the climate control display Celsius to Fahrenheits on own experience, on Infiniti Q45 (in my case it is 1999, touring)
Having studied the scheme I saw contact piece No. 12. On it at the version of Canada there has to be an earth, it and is an important point for switching between F/C
Remove the plastic panel under the steering column , unscrew the steel arch (on a photo I removed a carpet because I am prepared for full painting )
Further roughly speaking over a throttle pedal slightly more to the right you will see A/C Amplifier, it black color. Disconnect from it two plugs
It is also plug M44 and M45
You need to connect contact piece No. 12 of the plug M44 to contact piece No. 32 in the plug M45 (both wires black) because in a wire of contact piece No. 12 of the earth isn't present. Then at you will be displayed Celsius
I hope to somebody this information is useful
