Anyway....Another year has gone by and I am ready to give it another try.
I have verified all connections to proper RX, TX, CLK, 12v+, and GROUND. All of them are connected to the proper pins and I have verified most of the proper signals at the consult port.
At the port:
These seem fine.....................
12v = 12v
GROUND = GROUND
RX = 3.95v
but I am curious about the following signals at the consult port..............
TX = .0_v when cranking/running; .00v at key on, non-running
CLK = 4v when ground is on CLK and POS-probe is on 12v. (seems like a ground signal??)
As per software settings:
I am using Datascan 1.3.
My driver shows up under "ports" in device manager and is "working correctly."
It is assigned to COM1 @ 9600 in Datascan AND device manager...I see no reason the software could be at fault.
How can I inspect my cable for proper operation? Without being able to test it, I have no idea if it got fried somehow????
So....anyone got any input on the voltages I listed above or how to test my cable for flaws?? Any other ideas??
Sincerely,
--TJ
