ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Oct 01, 2010 1:43 pm
Do a leak down test with compressed air, more accurate the compression testing and does not rely on internal sealing of rings but will tell you about the condition of the engine. Compression testing if done to a cold engine without a charged battery will indicate low PSIG. Since this motor is isolated out of a car and complete, was it stored correctly, was gasoline left anywhere near it, was it in the cold, was it oiled, sprayed. Are valve assemblies still under spring pressure, have rings split or turned.
An engine improperly stored can be a nightmare of problems not even a compression test or leak down test can see. Scored crank, water or condensate internally...on and on it can go.
But if all your interested in is can it make compression do a leak down test and at least listen to the engine as it talks to you.
