to do a compression test right, you need to warm the engine to operating temp (180-195 degrees) then pull the fuel pump fuse and let the car die on its own. then pull all the plugs and use your compression gauge. when cranking with gauge in the spark plug hole you want to hold throttle wide open till the gauge reaches its highest measure. that will be your accurate reading.
ghx407 wrote:The biggest issue is large differences (over 15-20 psi) between cylinders. If you get 145-155 psi you'll probably have a good runner for a long time, but don't try forced induction without a rebuild.
this is correct. the factory says no more than 15 psi difference (i believe). im sure with all the plugs removed you would have decent numbers. but might be worth testing again.
