2K Marketing »
https://forums.nicoclub.com/2k-marketing-u52127.html
Sun Dec 31, 2006 6:51 am
I know someone posted some of this but I thought you all would like to see a complete code listing for all the wires. I just did remote windows and start in my car and had no suprises with these codes I received from a friend at Nissan.
Radio 12v brown + radio harness Radio Ground (chassis) Radio Ignition lt. green + radio harness Radio Illumination orange + radio harness Factory Amp Turn-on brown (subwoofer amp) + radio harness Power Antenna N/A LF Speaker +/- white - brown +,- radio harness RF Speaker +/- green - lt. blue +,- radio harness LR Speaker +/- purple - red +,- radio harness RR Speaker +/- lt. green - gray +,- radio harness 12volts blue (40A) + ignition harness Ignition red + ignition harness Parking Lights+ gray + driver kick, harness to rear Parking Lights- N/A Headlight blue (L), pink (R) + lights or IPDM E/R, brown 8 pin plug Trunk/Hatch Release blue to purple - pa kick or BCM, pin 30, wht 40P plug Power Sliding Door N/A Speed Sense lt. blue 8P radio harness or cluster, pin 4 Wipers yellow (L), blue (H) + motor or IPDM E/R, brown 12 pin plug LF Window up/dn red - gray A driver window switch in door RF Window up/dn white - lt. blue to purple A driver kick, door harness LR Window up/dn red to gray - orange to red A driver kick, door harness RR Window up/dn lt. green - yellow A driver kick, door harness Sun Roof open/close motor part of module
12volts blue (40A) + ignition harness Starter white + ignition harness Ignition red + ignition harness Power Lock gray - dr kick or BCM, pin 45, wht 15P plug Power Unlock purple to blue - dr kick or BCM, pin 46, wht 15P plug Lock Motor gray to lt. blue 5wi dr kick or BCM, pin 65, blk 15P plug Unlock Motor green 5wi dr kick or BCM, pin 59, blk 15P plug Disarm Defeat green 5wi dr kick or BCM, pin 66, blk 15P plug Parking Lights+ gray + driver kick, harness to rear Parking Lights- N/A Hazards blue - switch or BCM, pin 29, wht 40P plug Turn Signal(L) purple + dr kick or BCM, pin 60, blk 15P plug Turn Signal(R) white + pa kick or BCM, pin 61, blk 15P plug Door Trigger see notes - each kick or BCM behind glove box Dome Supervision brown - BCM, pin 63, black 15 pin plug Trunk/Hatch Pin pink to red - pa kick or BCM, pin 43, wht 15P plug Hood Pin N/A Trunk/Hatch Release blue to purple - pa kick or BCM, pin 30, wht 40P plug Power Sliding Door N/A Factory Alarm Arm green to yellow - dr kick or BCM, pin 8, wht 40P plug Factory Alarm Disarm brown - dr kick or BCM, pin 7, wht 40P plug Disarm No Unlock see factory alarm disarm Tachometer blue ac ECM, gray 32 pin plug, pin 13 Horn Trigger pink to red - horn switch
