BCC93QT »
https://forums.nicoclub.com/bcc93qt-u89202.html
Wed Feb 11, 2015 9:42 pm
Almost 100% Sure the side markers Front/Left are fully compatible. FYI Do not try to change them in 0 degree weather. They snap instantly. Always thought I had to remove the actual marker to replace the bulb but if you pull back the mud guards and do a little damage to your wrist it the bulb itself can be replaced.
As far as the front turn signals, as in the ones next to the actual headlamp they are not compatible. 1990-93 are different than the 1994-1996. Hope it helps ya. Welcome! Can you post some clean pics of your 94 Q45? Would love to see em
Off topic
BTW Where is everybody!
I started my 92 @ 2 degrees today for the first time since December 29th. Had to get a sticker. PASS. Have a front wheel issue thinking tie rod. Sitting at 375k and 400k isnt too promising as it sits too much. Never experienced a tie rod issue with a G50 Q45. To do list- Window motor, some fuses, caliper issue, maybe tie rod issue. Coolant leak. Still haven't replaced that POS advanced auto blower motor. New pads, Might as well throw rotors on. Have 3 sets of tires for it.
Work gives me a 2015 Sonata 2.0t Limited Or an Audi a3 sport hatch thing. Makes me search for a low mileage G50 Q at every red light.
