Well the difference is whether you lose power or gain a bitD_roc wrote:i need a CAI jut want to know weather to buy one of those cheap ebay ones for $35 or a ingen for $200, and what is the difference between the cheap one and the ingens b/c they both look the same aluminum tube and both had K & N filters ,
if you want a true CAI, then your only choice is the cattman intake. the injen 'CAI' is just routed lower in the engine bay, right behind the radiator. last i checked, the radiator is not the coolest spot in the bay. the cattman resolves this issue by routing the intake into the fender completely isolating it from any and all engine heat. this is done by removing the battery, cutting a hole below the battery tray, allowing the filter to sit just inside the fender. here it is free from the heat of the engine and any elements such as rain, snow, or whatever. i had this intake on my max and the only thing i changed was the filter. i put an AEM dryflow on it. the performance over that of the injen is astounding. and its only $215.D_roc wrote:i need a CAI jut want to know weather to buy one of those cheap ebay ones for $35 or a ingen for $200, and what is the difference between the cheap one and the ingens b/c they both look the same aluminum tube and both had K & N filters , also is it going to be a problem if it sit inside the engine bay or do i have to route it to the bumperthanksD
What do you mean, has there really been a hp/torque comparison between the two, with dyno proven results? And even so, this whole debate over short ram, cold air, we're talking a 1-2 hp difference. What I love about the Injen CAI is it's direct bolt-on, no mods, no cutting, just bolt on and hear it scream. End of story.jltibbs wrote:the performance over that of the injen is astounding.
Nah, you didn't ruffle any feathers at all, I just never heard of any more gains from the cattman over the Injen, so I was curious. And you keep saying a "true" CAI, yes the Injen sits down by the radiator, but it is completely away from any heat of the engine all together, with no drilling, so honestly, I think it's worth the extra $$. Also, someone mentioned earlier that you have to worry about water getting up into the filter...it takes a full 2 liters of water to run the risk of hydrolock. The Injen filter sits a lil above the low part of the bumper, so as long as you are going in any puddles deep enough to go over your front bumper, you got nothing to worry about! Good luck with your decision!jltibbs wrote: i just offered my knowledge and experiences to allow him to choose whats best for his pockets and personal preference. sorry if i ruffled your feathers.
Get any one that does not suck in hot air from the engine bay. I don't care who makes it, but a CAI that sucks in hot air is an oxymoron and should be called an HAI.nj1sh wrote:soo which one of these cai's will perform best on a 4th gen maxima? i cant decide which one to get now.
