Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Tue Jan 28, 2003 4:46 pm
1. you didnt search enough, the 240sx.org links/installs has a link on hwoto adjust your rear camber more than .5 degrees, when in doubt, get a set of rear upper arms that are adjustble from battle version, TEIn, cusco, etc.2.the springs and shock heights(unloaded) should be different front to rear, allong with the mounts, being the front is a strut and the rear is a more traditional shcoks/spring combo...
-chet
