loystock »
https://forums.nicoclub.com/loystock-u10145.html
Mon Aug 02, 2010 8:12 pm
Regardless of make, as a used car buyer, you have to do your own research, inspection and thorough test drive (city streets and highway) to find out if the car you are getting meets your requirements. A CarFax report is a starting point, vehicle maintenance history is recommended and due diligence will give you a better idea whether the car was well-maintained or abused/neglected by previous owner.
The I30/Maxima you are looking have better than average reliability. The 2004 4-speed Automatic Maxima was a problematic model. Regardless of make, O2 sensor typical lifetime is 100K miles. Most of the MAF sensors problems I've seen are related to gunk accumulation caused by irregular air filter replacement or worse, usage of oil-based filter. I've seen ignition coil problems but not specific to any model year.
IMO, for as long as you used Tier 1 Premium fuel, have regular oil and filter change, replace the air filter annually and use a good quality fuel system cleaner twice a year, the engine and related components should last for a long time. For the automatic transmission, a pan drop with pan and magnet cleaning and filter replacement and then fluid replacement (flush is better) every two years should extend its lifetime. I also use LubeGard Red ATF Protectant after each fluid replacement/flush. I have 5 Infinitis and all of them have original transmissions, ignition coils, injectors, MAF sensors, etc.). I have replaced an O2 sensor and KS in the 99 I30 (it was rear-ended twice and the last collision repair was @ $10K paid by the other party).
