Shizelkadizal »
https://forums.nicoclub.com/shizelkadizal-u226451.html
Sat Dec 14, 2013 7:05 pm
I would like to say something about the P1491 code. I kept getting it, and so I replaced the solenoid and bypass valve, as well as the solenoid on the canister, but in was still getting the code after a few days. I asked the dealer, and they said that the emissions is somewhat connected to the cruise control (maybe by vacuum...not sure). Since I purchase dot he 02 QX4 a couple months ago, the cruise control did not work. Anyway, the dealer said to fix the cruise would be $2500 for the laser. I, instead, took the laser off myself to take it apart and try to fix it myself. The P1491 immediately came on, and everytime I reset the codes, it came back. The code seemed to come on when I filled the gas, or when it rained or had bad weather. Anyway, I took the laser apart to find most of the board components were rusted off, and were bouncing around inside the laser box. I cleaned it out, cleaned the inside of the box with carb cleaner, and revealed the box with silicone so no more moisture would get in. I replied it in, reset the codes, unplugged the battery for a couple hours, and reconnected the battery. It's been three weeks, and no problems at all. I hope this helps someone who has done everything to try to fix the emissions issue, only to be stuck with the P1491 code.
