mexterra »
https://forums.nicoclub.com/mexterra-u88953.html
Mon Mar 10, 2008 5:43 am
NISTECH, I hate to dig up old post, and yes, I did read all of your threads about how to diagnose the sensor issue but I am a little confused. I am in the process of buying a used 2003 pathfinder from a local dealer. They agreed to replace the necessary parts for the SES issue before I purchase. The other day they replaced part number 23796-4w004 (Valve solenoid) Unfortunately, I don't know the original code or which side they replaced. My guess is the drivers side since it looks cleaner and the housing is silver and not brass like the passengers side. The car drove fine for about a mile then went into safe mode and triggered the SES light. I do work with both sensors and solenoids at work and know the difference. Here are the current codes:P0011 Camshaft Position Sensor/Act A/Bank 1P0021 Camshaft Position Sensor/Act A/Bank 2Both state that timing was advanced. My guess is this was due to the error.I found both sensors, removed them, and cleaned them. This helped for a short period and kept if out of safe mode, however, it is doing it again. I have to take the vehicle in today and just want to make sure I can advise them on which direction to go. One more note, the SES light, after being reset, will not come on until driving and not immediately after ignition. That is why I am confused. The OBD says sensors, but the way it is acting seems like a solenoid. What to do?
Modified by mexterra at 9:58 AM 3/12/2008
