Code P0507
edub809
Car: infiniti m45
I clean my throttle body recently, and right after i noticed, my check engine light on. Once i took off my foot off the brakes the car moved forward too quickly. I had the car checked, and got a code "P0507" Have anyone else had this issue, if so, how were you able to reset, for that the idle will be back to normal.
svard75
Car: 06 M35x
Do this
Accelerator Pedal Released Position Learning
DESCRIPTION
Accelerator Pedal Released Position Learning is an operation to learn the fully released position of the accelerator pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time harness connector of accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
Make sure that accelerator pedal is fully released.
Turn ignition switch ON and wait at least 2 seconds .
Turn ignition switch OFF and wait at least 10 seconds .
Then this
Throttle Valve Closed Position Learning
DESCRIPTION
Throttle Valve Closed Position Learning is an operation to learn the fully closed position of the throttle valve by monitoring the throttle position sensor output signal. It must be performed each time harness connector of electric throttle control actuator or ECM is disconnected.
OPERATION PROCEDURE
Turn ignition switch ON.
Turn ignition switch OFF and wait at least 10 seconds . Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Then this
Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds .
Repeat the following procedure quickly five times within 5 seconds .
Fully depress the accelerator pedal.
Fully release the accelerator pedal.
Wait 7 seconds , fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
Fully release the accelerator pedal within 3 seconds after the MIL turned ON.
Start engine and let it idle.
Wait 20 seconds .
Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
If idle speed and ignition timing are not within the specification, Idle Air Volume Learning will not be carried out successfully. In this case, find the cause of the incident by referring to the Diagnostic Procedure.
goldenchild7801
I also have to try this. Just what I was looking for.
