GerryO »
https://forums.nicoclub.com/gerryo-u56567.html
Mon Nov 16, 2009 6:45 pm
Code 32 could be as simple as a loose or cracked vacuum line between the EGR control solenoid and the EGR valve. How many miles on the engine?
The next hope would be clogged EGR tubes, as mentioned by Yoda, and a bad EGR valve would be worse than a bad KS, that at least can be relocated.
Code 34 could be a bad connection between the KS and the ECM, or a bad KS. Keep us posted.
