ovrthtop34 wrote:Not sure about the line. Will have to check. As far as bench bleed, explain. I am unfamiliar with that.
Ovrthtop34
Welcome to Nico
I've been following your problem for the past two weeks as I had a sticky clutch pedal almost three years ago. The clutch slave cylinder and fluid was replaced at no cost to me at 92257 miles as I was still under the extended Infiniti Elite warranty.
I dropped off my G at the dealer ate a few free snacks, picked up a new loaner and returned the following day to pick up my G.
I recall asking how much the work would have cost if I was not under warranty. I was told a few hundred dollars.
I purchased the paper version of the FSM for my G right after purchase just so I could determine if certain repairs were beyond my comfort level.
Perhaps you should do the same?
Part of my automotive library
From the FSM
CLUTCH FLUID PFP:00017
Bleeding ACS004O4
CAUTION:
_ Monitor fluid level in the reservoir tank to make sure it does not empty.
_ Do not spill clutch fluid onto painted surfaces. If it spills, wipe up immediately and wash the
affected area with water.
NOTE:
Do not use a vacuum assist or any other type of power bleeder on this system. Use of vacuum assist or power
bleeder will not purge all the air from the system.
1. Fill the master cylinder reservoir tank with new clutch fluid.
2. Connect a transparent vinyl hose to the air bleeder.
3. Depress the clutch pedal quickly and fully a few times and hold
it.
4. With clutch pedal depressed, open air bleeder. So I guess you need an assistant?
5. Close air bleeder.
6. Release clutch pedal and wait for 5 seconds.
7. Repeat steps 3 to 6 until no bubbles can be observed in the
brake fluid.
8. Tighten air bleeder to the specified torque. Refer
If you did not carefully follow the FSM instructions and you are over your head perhaps you should just call AAA and request a flatbed tow truck and take it to the local Infiniti dealer. At least you'll have it back in a day or two.
Just my $.02
Good luck
Telcoman
