Clutch release mechanism help
cleopp3
Car: 93 nissan 240sx
A while ago i was having problems with my clutch release system, had to drop the transmission to see and in the process I did the dampener delete. found that the front cover assembly was busted (shaft that the bearing slides on) Note: the clutch is a brand new oem exedy kit. so i replaced that and the seals for the transmission. installed the transmission again got everything where its supposed to be and fired her up. drove it around the block a few times and everything seemed to be fine until the pedal felt like it was sticking again (had to creep it up with my toes) got it back in the garage and bled it to try to fix the return motion on the pedal. weird thing is I have good amount of pressure and I can engage any gear yet when I let the pedal out while in 1st gear or any gear for that fact car does not stall?? clutch not burnt out either pretty much brand new. any suggestions? fork?, release sleeve?, pivot ball? or one of the two broken sensors? (reverse and one right next to it? crank angle?
Hijacker
Car: '92 240sx Convertible
'94 F-150
It just needs to have the pedal readjusted. You can do that by lengthening/shortening the arm for the master cylinder
cleopp3
Ya I tried altering the length thru the adjustable rod on the master but no effect feels as if the fork is not pivoting all the way back , like I said if the pedals all the way out and the the car does not stall yet I feel the car slowly creeping forward like the clutch is barley touching the plate but the pedals all the way out. I looked at the fork and it looks like its titled to one side maybe meaning it slipped off the release bearing sleeve. guess I'll have to drop it again!! damn 2nd time already thanks for ur input tho.
scottydog
Car: 1992 240sx
Can you pull the rubber cover off the release fork lever and reach in to put it back in place? Make sure the little clip is as it should be to hold it in place.
Lots of work pulling the transmission again... :-(
cleopp3
Ya I tried peeking into the boot 2 check the fork seemed to be locked in place knocked it a little and it returned back but think it has to do with how the fork is sitting on the release sleeve which is out of reach through where the boot was. tryin to figure all the possibilities so maybe I dont have to drop it but I can drop the transmission in 45mins just a Bi*ch to put it back in : ( thinkin if I should just replace all the components to the release system; release sleeve, fork and retainer springs. good idea???
scottydog
Car: 1992 240sx
The clip that holds the withdrawal lever onto the post should be reachable to keep the lever in position. If it came loose from the throwout bearing I'm not sure you can get it back in without dropping the transmission.
You did pack the to bearing with grease? Might the bearing be stuck on the input shaft?
I can send you the manual showing the diagrams for this.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
cleopp3
I pretty much followed the assembling part of the fork and sleeve with the retainer springs. I lubricated the contact points including the pivot ball but I didnt as u say pack a bunch of grease in there maybe doing that and just replacing all the componets will eliminate all problems from occuring, like I said before I have a new front cover assembly. all other peices are the original ones. fork, retainers, and pivot ball. diagram is nice tho it gives me a way better idea of what Im suppose to be looking at. Thanks again 4 all ur help. sucks hella bad cuz its my only car and Im the only one who works on it. so its a great learning experience also Im just hoping it wont be an expensive one lol. note that its my first time ever working under there. : )
Hijacker
'94 F-150
Posi...you're retainer clip for the throwout bearing is on backwards. Just FYI
positron1
Hijacker wrote:Posi...you're retainer clip for the throwout bearing is on backwards. Just FYI
Whoops, thanks for the heads up!
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
clean and lube the fork pivot and pivot ball.
cleopp3
Any particular grease??? and what would cause the fork to lock when pushed out, preventing a full return?? I could feel the fork nout coming all the way back because like I said earlier I could be in 1st gear with the clutch pedal all they way out and it wont stall. note clutch is new only 500miles on it.
scottydog
Car: 1992 240sx
Use lithium grease to lube the retaining sleeve and a bit on the fulcrum. If the retaining clip wasn't installed right the fork would come off the fulcrum post and not work properly.
The following link goes to the manual chapter for the clutch install, with diagrams showing how the fork clip is installed.
http://www.adrive.com/home/downloadfile/25505502
Modified by scottydog at 10:14 PM 5/14/2008
cleopp3
Yo link didnt work , anybody have a detailed view or site of exactly how to install the clutch release system for a 93 se fastback????
scottydog
Car: 1992 240sx
Drop me an email to swmack*@*gmail.com taking out the "*". I'll send you the whole manual.
cleopp3
Parts on the way, new fork, new release sleeve, new TOB. ? Will the oem Nissan TOB work alright with an oem exedy clutch kit???
cleopp3
ya the weird thing about mine is the pressure is there no doubt on that, since I did the dampener delete it feels alot more straight forward. what happens is that when I press it down it does disengage the clutch so I can put it into any gear but what happens is when im releasing it does come back up all the way full release but fork seems to lock in place making the slave cylinder lock(along with the fork) but the pedal is still all the way out causing the diaphram fingers to be still slightly in still preventing the clutch pads to be all way the against the contact point(there fore causing the slipping feeling) even tho the pedal is at its full all the way out position. Anyone????
