DeusEx »
https://forums.nicoclub.com/deusex-u77396.html
Mon Mar 17, 2008 6:47 am
ill try to be as brief and as informative as i can. To sum it up my clutch isnt working properly. The cylinder that pumps the hydraulic fluid broke, and was replaced. After that my clutch has been behaving strange, even after adjustments have been made to the cylinder. here are my gripes:
-it is very difficult to shift into first or second gears. Its so difficult i have to ram my back against the seat sometimes.... But shifting into any gear can become difficult, but 1st and 2nd are the hardest.-sometimes the grinding noise is heard when shifting gears. -If the hydraulic cylinder is adjusted, the clutch will operate perfectly for 2-3 days and then this same problem starts happening again.
So what can be the culprit ? When it works its a wonder to drive, when it doesnt i want to shoot myself.
Thanks for any help.
Modified by DeusEx at 11:34 AM 3/17/2008
Modified by DeusEx at 12:28 PM 3/17/2008
