BusyBadger »
https://forums.nicoclub.com/busybadger-u28281.html
Tue Oct 05, 2010 9:06 pm
I'm betting that there is a problem (in a hard to see area) with the clutch master cylinder, it sounds like it's not holding pressure (and making the clutch pedal) return upright. What's odd is that you haven't noticed any change in fluid level, a sure sign of a leak. I think (I'll have to check the FSM or you can if you get a chance before I do) that there's a return spring for the clutch pedal, but given that you just replaced your clutch I'd find it a little hard to believe the problem wasn't related to that, but the spring(s) is still worth checking out.
