johnnyballs180 »
https://forums.nicoclub.com/johnnyballs180-u106780.html
Tue Nov 18, 2008 2:43 pm
i recently started another thread about this same issue.. i didn't realize it was a repeat.
so, Marko, you're saying that adjusting the rod so that there's a little more freeplay eliminated the problem? i flushed my clutch hydraulic system, removed the dampener box, checked all seals, but nothing changed.
i DID, however, instal a new clutch/flywheel a couple months ago. after it broke in, i adjusted the clutch pedal juuuuust a tad; i went from +- 1 inch to roughly 1/4 inches, and that's when the trouble started.
a couple days ago, i also lowered the pedal, thinking that when i adjusted it out, the problem started, so if i put it back in a little, the problem might go away.. and it helped, but not much. i get worried when i drive, that i might have constant pressure on the clutch. i would pull over on the side of the road when the pedal was rock-solid, so i could adjust the pedal down a bit. but when THAT happened, the engagment point changed, and i'd have a couple inches of free play.it's like i can't win
is your pedal still holding?
