Shocks, springs, sway bars, coliovers, bushings, brakes, rims, tires - You name it, this is the spot to discuss Versa suspension components and modifications!
Clunking sounds when turning or going over bumps
Postby equlizer » Sat Apr 11, 2009 11:56 pm
Yeh i think its been discussed before by many and i think even me once Anyways, it was in for repairs last monday and they said the suspension was loose so they tightened it. Well everything was great for about an hour then the sounds became worse Its going back in this monday and they have no idea what they are going to do about it. Ball joints and tie rod stuff was A OK so what else could it be?
equlizer
Car: Nissan Versa SL with SVT tranny
Re: Clunking sounds when turning or going over bumps (equlizer)
Postby audtatious » Sun Apr 12, 2009 1:07 pm
Could be struts or the springs may not be seated properly if everything else checks out.
2008 Infiniti G37s | K&N drop-in's | Invidia Gemini CBE | Cobb AccessPort | GTspec FSTB | Tein H-tech springs
To be installed: Invidia HFC's
audtatious
Car: 2008 G37s Coupe - 2007 G35s Sedan
Postby CPS » Sun Apr 12, 2009 5:37 pm
54325-ED02A strut bearings should fix your concern. Current service bulletin.
CPS
Re: Clunking sounds when turning or going over bumps (CPS)
Postby Driving Instructor » Sun Apr 12, 2009 5:41 pm
They changed my strut mounts last week....... same noise.
Now, my noise sounds more like "hitting a chunk of ice" when I mostly turn to the right.
Good luck!
Driving Instructor
Car: 2007 nissan versa SL CVT Red
Re: Clunking sounds when turning or going over bumps (Driving Instructor)
Postby Vapor77 » Fri Apr 17, 2009 8:33 am
Hey Guys,
I've just been around the world with this issue myself. I thought I would help anyone else out there so that they may not have to go through what I have.
I have a 2008 Hatch SL that did the same exact thing you (and others) are describing.
First I took it in and they checked the suspension and said no problem found.
I took it back a few weeks later and they had it for a couple weeks and replaced the entire steering rack.
Drove it two weeks no noise. After two weeks, the noise was back.
Took it back in they put new strut bearings in (per the service buliten).
No change, noise still there.
Took it to another dealer, they had car for two weeks.
They replaced the steering link (small shaft between steering rack and steering column with universal joints on both ends).
That fixed the problem and hjave not had it return yet.
I have talked with two others at this point that had that fix work for them as well.
Everyone I talked to that had the rack or the strut bearings replaced had the noise come back.
The dealer that correctly located the noise is in Columbia, TN. (BARR Motor Company Nissan or simply BARR Nissan).
Call their service department and ask to speak with the manager (James) and he can tell you all about it.
Vapor77
Car: 2008 Versa Hatchback SL 6MT
Re: Clunking sounds when turning or going over bumps (Vapor77)
Postby Concord » Wed May 27, 2009 3:59 pm
I have same issue. Went for a ride with tech and I suggested it might be lower steering joint. After an hour of troubleshooting they have ordered the entire rack.(Sound familiar)
Installation is tomorrow. I have a strong feeling I'll be back for the steering joint.
Concord
Re: Clunking sounds when turning or going over bumps (Concord)
Postby Knightro2 » Thu May 28, 2009 4:08 am
Yes, this has been covered many times before and I had the same issue with my 2008 V SL. They replaced the Steering Joint Assembly and that resolved the issue.
Some people are like Slinkies...Not really good for anything but they bring a smile to your face when pushed down the stairs.
Past Cars
1990 Ford Bronco II - '94 - '98
1992 Mitsubishi 3000GT SL - '98 - '98
1998 Chevy S-10 - '98 - '04
2004 Nissan Xterra - '04 - '07
2008 Nissan Versa SL - '07 - Present
Knightro2
Car: 2008 Nissan Versa SL
Re: Clunking sounds when turning or going over bumps (Knightro2)
Postby Codelicious » Thu May 28, 2009 8:05 am
People who work at a car dealership always want to be right. They would probably replace the whole rest of the car before they ever listened to me if I had this problem. lol
Project: Dark Knight
Car Domain: http://www.cardomain.com/ride/3827990
Codelicious
Car: 2008 Nissan Versa 1.8 SL
Postby eeshazor » Thu May 28, 2009 10:37 am
I also have the same problem...
I thought maybe it was just me overexaggerating about it,
but i can go 3 miles an hour over a bump and it make that loud noise.
thanks guys!
eeshazor
Car: 2009 Nissan Versa 1.8L Sedan, Brilliant Silver. Stillen cold-air intake with K&N air filter. Neon blue LED lights under driver & passenger feet. De-badged.
Re: Clunking sounds when turning or going over bumps (eeshazor)
Postby DrivingHabit » Thu May 28, 2009 2:06 pm
I just get it to pop once or twice while leaving out of the driveway, almost sounds like something loose in the back trunk.
-Always Drive Safe!!!
DrivingHabit
Car: 2009 Nissan Versa SL
Re: Clunking sounds when turning or going over bumps (DrivingHabit)
Postby Concord » Fri May 29, 2009 6:41 am
Cars is at dealership having rack installed today. The tech who was with me when I duplicated "pop" will be doing install. I made a point to service writer to have tech drive back to same location after new rack is installed to verify fix. I'll update.
Concord
Postby sooner4x4 » Fri May 29, 2009 7:35 pm
Having had the same experience and reading through all of the clunking threads, it seems like there are two common issues with different fixes.
If the noise is a clunk when turning to the right, replacing the steering joint fixes it. This was my experience.
Others have reported a noise when going over bumps, and quite a few folks have said something with the strut bearing is the problem. I have not experienced this.
Good luck with yours. Multiple trips to the dealership can get very frustrating.
sooner4x4
Car: 2007 Versa S sedan
Re: Clunking sounds when turning or going over bumps (sooner4x4)
Postby Concord » Sat May 30, 2009 11:02 am
Ok Rack replaced. "pop" in steering has been greatly reduced but is still there intermittanly. Location where I was able to duplicate it almost every time near dealership, I could not after driving from dealers lot. After testing it over and over at different location I can make it happen once every 3 or 4X. Trouble now is I have to make it happen when I bring it back.
Concord
Postby DrivingHabit » Mon Jun 01, 2009 10:01 am
Any new updates of the problem????
DrivingHabit
Postby Concord » Wed Jun 10, 2009 3:45 am
I must say it has improved. I can still feel popping if I hit the right bump at less than 5mph with wheel turned to the right. Im not bringing it back until it can be duplicated easily. Another member with a rack replacement had his popping return after 2 weeks.
Concord
Postby JH51 » Fri Aug 07, 2009 5:56 am
Hi!,
I have a 2007 Versa. I've noticed this problem from very early in ownership. The car makes a klunking niose when I'm turning to the right at low speed and the two surfaces that I am crossing are uneven. I have complained about it many times but could not get it to make the klunking noise for the dealership. Finally, a few weeks ago, the Tech that checked it out got it to make the same noise for him. They ordered an intermediate steering shaft and it is being installed today. I'll let you know if it helps!
Take Care!
Jeff
JH51
Car: 2007 Nissan Versa
Re: Clunking sounds when turning or going over bumps (JH51)
Postby JH51 » Tue Aug 25, 2009 10:07 am
HI!,
I had the intermetiate steering shaft replaced about 10 days ago! That took care of the clunking noise! I just hope it stays fixed!
JH51
Postby The Edge » Fri Oct 09, 2009 3:56 am
Strut bearing replaced........still klunking
Strut replaced.........still klunking
Intermediate steering shaft replaced...........still klunking but less noticeable but still there
I'm tired of going to the dealer. What the hell could be causing this. Gonna take it back again in a few weeks and see what happens. Thankfully I have a great dealer and they have been very helpful.
The Edge
Car: Nissan Versa SL Magnetic Grey 6 Speed MT Convenience Package
Postby weems84 » Fri Oct 09, 2009 4:14 pm
Knightro2 wrote:Yes, this has been covered many times before and I had the same issue with my 2008 V SL. They replaced the Steering Joint Assembly and that resolved the issue.
replaced the same thing on our versa s and it solved the problem too.
weems84
Car: Versa SL
Re: Clunking sounds when turning or going over bumps (The Edge)
Postby raiders4403 » Mon Jan 18, 2010 2:32 am
ihad same problem with my 07 sadan, dealership replaced strut mounts, strut bearings, lower stearing colum yet the noise still remained. finally they replaced the LOWER SUB FRAME because it had worn bushings.....PROBLEM FIXED !! its been about 10k miles since and NO noises ! its covered under warranty so why not try it.
raiders4403
Car: 2007 VERSA S
Re: Clunking sounds when turning or going over bumps (raiders4403)
Postby The Edge » Fri Mar 05, 2010 1:27 pm
yup, same part replaced here and after 7 trips to the dealer finally fixed......2 weeks later i traded my Versa for a 2010 Pathfinder
The Edge
Postby gorge1 » Fri Apr 09, 2010 6:57 am
I took mine in for these same symptoms and there were two technical bulletins they found to address this issue. They replaced the upper strut bearings and intermediate steering shaft. Car drives great with no noises, but now the steering wheel is off center, so will need to take it back to correct that.
gorge1
Car: 2008 Nissan Versa S Hatchback
Return to Versa Suspension, Brakes, Rims and Tires
