fleurys »
https://forums.nicoclub.com/fleurys-u158666.html
Tue Feb 07, 2012 11:13 am
i guess if you are lucky, it means the screw is still in the cylinder chamber and has not passed yet through an exhaust valve.. If I were you, I would take a magnet on a stick and remove each sparkplug , one at a time, and see if I could pick it up like this... Just a thought... The other reason I know about a tick noise is when the truck is low on oil...(but Ithink this was with the 3.3, not the 3.5)...still worth a look...
If you engine is not taking oil, then the screw has not killed your engine yet... but you can be sure that if it goes through a valve port then it will most certainly do some damage.... go get a magnet fast...and don't use it until you know for sure nothing is in there....
S.
