Europeenne wrote:i emailed the dealership to ask what oil they had used on the last change, so i could just top it off or put a bottle full in without having to drain out what's currently inside
In general, it is not an issue to mix oils - even synthetic with dino would be okay.
Of course, I would not make a practice of this per se, but adding in another bottle of something good will not hurt anything.
Europeenne wrote:he came back with this
pennzoil gold synthetic blend 5w-30
your guys' thoughts on this?
should i have it drained and put in full synthetic or is this hybrid blend okay?
Again, in general, as long as it is a good reputable brand, then it is not an issue ... as long as the oil change interval is not too long. And, Pennzoil is a good brand.
FWIW, I use Mobil 1 Synthetic 0W-40, but I would be just as fine with a good dino oil (like Castrol GTX, Quaker State, Pennzoil, etc.) of the correct weight 5W-30, and would not have qualms about it.
My oil (and filter) change interval is set at 3750 miles as a "halfway" point between regular 7500 mile checks - just for convenience.
Z
