svard75 »
https://forums.nicoclub.com/svard75-u133637.html
Fri Aug 30, 2013 4:37 am
Cool, so they swapped rear drive shafts too? I've got to try that myself one day. I was told by a number of people that the TSB fix is temporary and the click returns after a few years and depending on environmental conditions could be sooner. It may be worth doing anyway. I found a forum where someone had posted details on how to remove the rear axles without removing the wheel hub. There are 6 or 9 (Can't remember) bolts holding each axle to the differential and simply removing those bolts and the large wheel hub nut will allow you to bang the axles out and down without removing the wheel hubs. While I am in there I would likely use something like permatex disc brake quiet with grease. Grease eventually works its way out the permatex stuff would be stuck there forever!
