WTH happened there.gwoods wrote:I have almost 77k miles. recently at 69k I received new throttle bodies and a new ECU right after a spark plug change.
I'll tell you off line all I can say is never ever never ever clean your throttle bodies!SteveTheTech wrote:WTH happened there.
The newer MAFs are not as fragile as they used to be. The hot wire is still thin but it stronger. I see bugs get lodged in there frequently and the usually just burn up.gwoods wrote:from my Nico research I know that you DO NOT want to actually touch the MAF with anything but liquid. The MAF has a electical wire as thick as a human hair that makes it work if you disrupt this wire the MAF is trash.
I was planning on using the CRC MAF cleaner and giving it plenty of time to dry.
Other things that can cause surging is timing and injectors as well.tjrob2000 wrote:I came across this thread doing a search on cleaning the MAF. I have a 2007 G35 Journey sedan with the dual TB's and am experiencing the same exact problem the OP states here in addition to some surging at light throttle below 2000 rpm (pretty sure only below 2k as it seems to be ok above it). My problems only occur while the engine/transmission/MAF's are warming up. Once it's been driven for 15 minutes or so it is smooth. I can't say anything about WOT since I haven't gone there yet. I bought the car with 94,xxx miles and it is at 105,xxx now. Problem started ~2-3k miles ago.
SteveTheTech, any input on this? I've gone through the accelerator pedal release position learning and am pretty certain I did the idle air learning correctly along with the TB valve learning, but no change.
GWoods, did you resolve your issue? I don't see a post with a fix.
