the converted wrote:You can't clean them. The chemicals in them react with the exhaust, and after a while are completely used up. I'm assuming that you have a 420 or a 430 code? I did the spark plug anti-fouler trick on mine and it works fine.
There are no chemicals inside of ANY cat...it's the precious metals that convert the exhaust into CO2...watch:
http://www.youtube.com/watch?v=GkRXhfgZ ... re=related
so in my mind...if i can remove the buildup of carbon inside of the cat, the platinum and other metals will be cleaner and more able to do their job!
A computer engineer and chemist friend of mine suggested stuffing the cat pipe with potato skins a little at a time, and blasting it with a torch...there is a chemical in the potato skin smoke that dissolve carbon build up!
if cleaning it doesn't work, i will weld in a universal short cat like the one below for $60!
