EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.html
Wed Mar 15, 2017 8:30 pm
Hmm, after watching the video I don't think it's engine oil related anymore. For giggles, look up "maxima chain rattle".
1. Sounds like a pump cavitating. Check your power steering fluid level. Might as well check the fan fluid level as well although that's on the left side of the car.
Does the noise get any worse when you turn your steering wheel in park?
2. It could also be bad bearings. Can you give it a little more throttle while recording so we can hear what it sounds like at higher speed?
Then if you're up for a little troubleshooting, get a stethoscope (long solid object will work). Place it on the non-rotating part of any accessory that the belt touches. If it is indeed a bearing you'll hear the popping noises in your ear when the other end of your stethoscope is on the alternator housing for example.
If you've got a surgeon's hand, try to actually place the stethoscope on the bolt in the middle of the tensioner & idler pulleys. The water pump, alternator & PS pump middle bolts/nuts aren't stationary bolts, so you'll have to put those on the part casings/housings.
