Steering wheel is from ebay. had bought the complete quick release from ebay but that stuff didn't even fit and felt too cheap.Hijacker wrote:Looks good and clean! What wheel and hub did you go with?
thx. from reading other posts it seems as piston #2 always seems to be the one that goes out first. was it also piston number 2? Its as if it was made to be the weakest linkchaos2000 wrote:good ish so far bro!!! your #2 piston looks just like mine did on my s14sr in my s13 hatch.
ok, i figured what was going on here. well, i was also having another problem with my car other than this. When ever i turned up the boost for my car, it wouldn't go past 9psi of boost. the nipple i made for the hot side as a vaccuum line had a boost leak. i clogged the leak up with some jb weld. i kept having the same problem so i switched it with one of the nipples on the tb and capped off the nipple on the hot pipe. after that, my car ran like a champ. i boosted up to 14psi on 5th gear 5500rpm. stopped right away and lowered the boost a bit till i got 12psi just where i wanted it. i realized i had more torque on lower rpms than before. i moved my timing to TDC and it worked. No more bogging.ciscos13 wrote:i'm having a bogging issue with my sr. the car starts to bogg right around 2.5k. the car feels like its not going anywhere. after doing some checking here and there, i found out my car would start to run right after i advance the timing by two teeth. If i set it back to TDC it starts to do it again. Does anyone know why this would occur?
I used bondo. I first had to place a sheet a paper (from under the trunk) under the hole to hold the first layer of bondo. I let it dry, then placed some more to cover the hole completely then sanded it down until it cameout flat and smooth. and just primered it.highwhey wrote:what did you use to cover up the holes in the trunk? nice to see another person from phx![]()
i need to paint my s13 as well but it also has the damn holes in the trunk. you do all the work yourself? pretty impressive and nice progress.
These are NGKs, they are bkr7e a step colder than the bkr6e and yes i did gap them. About the AFR i have no idea since im not running oneLobo240sx wrote:What kind of plugs are those?? You need some NGK's for sure. Those plugs probably aren't rated for a SR turbo engine. Might be running too lean. Did you gap the plugs at all or they came out like that? How is your AFR?
Yellow4g63 wrote:Spark plugs won't make you run lean. Your having other major problems with fuel. Did you change to bigger fuel pump like a 255lph? If you did then rewire the fuel pump with a relay so it gets 12v directly. Your running way too lean and prob too much ignition advance for the weather you drive in. You prob toasted a piston again, while forged pistons are stronger they are not indestructible.
