SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Sat Apr 25, 2009 11:21 am
The fuse block you will need to look at is the one behind the parking brake pedal. The list of fuses is on the cover. You may also want to look at whatever you plugged into the power socket. They are limited to 15A and almost nothing should be drawing more than that. I have seen cell phone chargers and portable Nav units internally short and repeatedly open fuses. If you have small children that like to stick pennies in places they do not belong it could also short out the socket.
You should have a spare 15A mini fuse located inside the fuse block and a fuse puller in the center. Maybe someone can post a pic.
