Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Sun May 06, 2007 1:53 pm
Okay, there are no pics in the FSM. The IAT is in between the filter, and the MAF. There are only 2 wires in the IAT.Not trying to burst your bubble, but chips are not really worth while in our cars. They can cause throwing of codes, and more likely than not run you lean, since it will b telling your car that the air is hotter than what it really is, so the ECU will output less fuel, and you will receive an extra horse or two, but then will be running hotter, and potentially having other problems, such as spark knock, which will cause the timing to be retarded, and lose the extra power that you gained by chipping the car, but you will still be running hot. Good luck, if you have anyother questions, feel free to ask, and let us know how it works out for you!
