check engine light
check engine light
Postby m30driver » Tue Jul 24, 2012 6:42 pm
What's up I'm new to the vg engines. I just recently got an m30 two tone pearl white on gold. I didn't find much help on f31 club. The car drives fine but randomly the engine light will come on and begin to idle rough. Then the light goes away and isles normal. Has this happen to anyone before?? I inspected the injectors and found most of the connectors brittle and don't snap on securely. Luckily as it was idling rough I moved one connector that was pretty brittle, I moved it and it idled perfectly. So I ordered 6 new connectors now I just have to wait for them to see if this helps. Oh and also every time the light comes on I've checked the ecu for codes and got 55 that's the all ok code right? Thanks for any input
m30driver
Car: M30
Re: check engine light
Postby Q451990 » Tue Jul 24, 2012 8:54 pm
:welcome: to NICO!
I'd say our culprit is probably those connectors if moving it helped. 55 is the "OK" code.
You can find the factory service manual for your M here. http://www.nicoclub.com/FSM/M/
Good luck!
Heath
1990 Infiniti Q45 AKA "Q2"
2005 Infiniti G35 Sedan A/T
2004 Nissan Frontier King Cab M/T
2012 Nissan Xterra 2WD S
Q451990
Car: 1990 Q45 - 102K, 2005 G35 Sedan - 96K, 2004 Frontier M/T - 72K, 2012 Xterra (Mom's)
Postby m30driver » Wed Jul 25, 2012 11:52 am
thanks for the welcome! hopefully i cant get more info here as well. thanks for the link for the fsm im downloading and printing it lol.
m30driver
Car: M30
Return to J30 Forum / M30 Forum
