the converted wrote:Sounds like a crank or cam position sensor. I have a brand new crank position that I bought trying to troubleshoot something if it ends up being that.
Go and pull your codes by turning the key on waiting 3 seconds, 5 quick full throttle pedal presses, wait 7 seconds, and then hold down the throttle for 10 seconds and the check engine light will blink out the code to you.
I tried pulling the code with the above method but it didn't work. This is exactly what I did. Please tell me if I didn't do it correctly.
1) I turned the key to ON position, did not turn the engine on.2) I pressed gas pedal 5 times quick then waited 7 secs.3) I pressed and held down the gas pedal for 10 secs
