exeunt »
https://forums.nicoclub.com/exeunt-u78015.html
Sun Feb 24, 2008 6:21 am
If it is, then they've hidden the function well, and haven't publicized it. I've heard a rumour that the following works though, but I haven't tried it:
1. Turn the car on2. Put the car in reverse3. Open the rear passenger side window all the way.4. Turn on the rear window wipers to INT.5. Back the car up 5 feet (no more, no less!)6. Turn the radio on, and change the channel to 99.9FM7. Put the car in forward.8. Turn the rear windshield wipers off.9. Turn the volume up to max.10. Move the car forward 4 feet.11. Close the rear passenger window.12. Shut off the radio.
If all has worked, the trip computer should now be in metric. Good luck!
(If it didn't work, try doing it again a few times. Sometimes it helps to do it at 4AM when the moon is full. )
