Swimshark, we just picked up a '93 service manual at Ebay for $30 used. I suppose this is one of the same type as you guys are referencing? The only problem with mine is that it does not give you any instructions to removing and/or installing exhaust manifolds. So, naturally, we are at a loss on this.
Also, both manifolds of mine are leaking and making loud noises. There is also no power going up inclines. I found a place who has a right and left manifold at a discount parts store, but I am uncertain if they are originals from an actual '93, or are they newer. I will still need to find out. He wants $60 a piece for them.
By the way, I called Nissan and found out that they will charge me $750 for each manifold, and each one would require some sort of adapter.
Does $750 each sound about right? To me, it sounds outrageous.
Thanks so much for your input on all of this. Sure appreciate it more than words could say.
Vicky
