Changed the Dash Lights
rydebynite
Car: 2002 Nissan Pathfinder 3.5l V-6
No the original bulb won't work either. A couple months back it would go out and then cutt back on every now and then. Then about a month ago the right side went out and never came back on. When its not so damn cold im going to pull it back out and see if i can figure this s*** out. I used different bulb housings and still got nothing. figured it might have been a bad LED so i swapped with the side that worked and still got nothing!
VG33QX4
Car: 2000 Infiniti QX4
kind of curious. i just read a post, guy said using white leds showed slightly blue in the cluster, thats what im going for so i ordered regular forward firing led bulbs not SMT, just curious about what it will look like, i figured the smt would be too bright. anybody got pics at night of non smt led bulbs? thanks qx4 if possible 2000
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
VG33QX4 wrote:kind of curious. i just read a post, guy said using white leds showed slightly blue in the cluster, thats what im going for so i ordered regular forward firing led bulbs not SMT, just curious about what it will look like, i figured the smt would be too bright. anybody got pics at night of non smt led bulbs? thanks qx4 if possible 2000
You bought something like these to put in your illumination bases? They will be way too dim I think. One of those LEDs (well, it was a red one, just had one left over, dunno if color would matter much though) couldn't even light my odometer evenly.
VG33QX4
yea thats what i got
color does matter white is 6200 mcd blue is 1860 and red is 5600mcd
so white led much brighter but i was just curious if anyone had a picture of what it would look like
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
VG33QX4 wrote:yea thats what i got
dont think those lights would be as effective as the matrix leds sold by autolumination.
VG33QX4
probably not any specs on those brightness?
VG33QX4
ordered wedge led, round led and smd single i shall play and see what i like spent like 10 bucks for 18 bulbs lol
i got some smd map lights, and a bunch of random 168 leds just to have around. spent like a total of 20 bucks and got like 50 leds went nuts on ebay woot
Towncivilian
Here's a bunch of decent pictures of my almost complete interior LED conversion:
Dashboard (every single bulb was replaced with an LED, even the warning lights; illumination LEDs are white, not blue):
Image Image Image Image Image Image
Map & dome lights (sorry for the crappy first picture):
Image Image
Window switch packs (don't have picture of the passenger side, sorry):
Image Image
A/C unit controls and crappy job with the defroster switch (I'd re-do that switch and put an LED the rear hazard switch if the damn switches weren't impossible to reassemble); I also made my clock always at maximum brightness since I usually drive with headlights on during the day and I'd prefer to be able to read the clock:
Shifter, ashtray, and glovebox:
Image Image
VG33QX4
What kind led you use for gauge? Smd ? One led or three
What's in your odometer spot
Towncivilian
VG33QX4 wrote:What kind led you use for gauge? Smd ? One led or three
SMD tri-LED in all 4 illumination spots and odometer. These, specifically. "SERVICE ENGINE SOON" has a Red 74-XHP LED, while every other warning light has a normal 74-x LED of matching color (except O/D off, the gas warning light, and the (nonfunctional, since I'm in the US) washer fluid light).
VG33QX4
Ok well in my qx4. The ashtray bulb is a 2721 size not a 74.
So in your shifter location you have a smd tri power?
The tri led are not overwhelmingly bright? I got the single smd and I am wondering if I should have got the tris
It appears nobody has a pic of single smd nor regular led
Towncivilian
VG33QX4 wrote:Ok well in my qx4. The ashtray bulb is a 2721 size not a 74.
Shifter is a 5-LED 168 bulb, cool white.
Tri-leds are perfect in my opinion for the illumination, odometer, and manual A/C unit controls.
VG33QX4
what is the correct size in led for the 2721 bulb all over it says 2721 same as 74 but this is not true i have verified this in my own vehicle attempting to place a 74 in the ashtray part results in it being too big.
Towncivilian
VG33QX4 wrote:what is the correct size in led for the 2721 bulb all over it says 2721 same as 74 but this is not true i have verified this in my own vehicle attempting to place a 74 in the ashtray part results in it being too big.
These will fit.
jpedderson
Car: 2001 Nissan Pathfinder LE 4WD
That looks sweet! Is your odo really that bright or is it just the pic?
Towncivilian
jpedderson wrote:That looks sweet! Is your odo really that bright or is it just the pic?
It's just the pic. It's still significantly brighter than the stock bulb, but it's still readable and not blinding.
VG33QX4
ok so i went with the tri smd sticks they work great look perfect no dead spots any other leds have dead spots
so check this those things are way smaller than normal 74 bulbs. i had to bend up the metal tabs in order to make them fit without falling out
and when i had the dimmer all the way up one of the bulbs flickered so i had to turn it down a hair. ever since i reduced the brightness it stopped blinking. stupid.
so i also put 4smd 194 in my parking lights and it looks bad a**. perfect match to my 6000k hids. 3 bucks off ebay.
i threw a blue wide angle 194 in the shifter and its looks perfect but is blue and matches nothing but whatever
also fyi the cheapy dash bulbs from ebay fit the gauge and the ashtray. i have figured out that they are slightly smaller than 74 and when they are advertised it says fits 74 and 2721 they are correct it does but its loose in 74s just an fyi to everyone out there cause nobody said it
i bought every variation of led light wide angle narrow angle, smd, multiple smd
simply to test out them all i spend a total of like 35 dollars to change every light out.
EsotericImage
Car: 99 Civic on 10lbs boost
02 Pathy as DD
ok, got the gauge cluster #74, dome lights, and map lights..ashtray i got now thx to the poster (24)
What bulbs are the window switches?
Innovazn
EsotericImage wrote:ok, got the gauge cluster #74, dome lights, and map lights..ashtray i got now thx to the poster (24)
how-to-changing-window-lock-switch-led-s-t442389.html
you cant just "change" it. Soldering is involved.
EsotericImage
02 Pathy as DD
Thanks for the heads up! looks too complicated for just the window switches.. thanks for the link tho. :dblthumb:
VG33QX4
where to get twist lock bases. mine are so worn out. where can i get new ones
EsotericImage
02 Pathy as DD
autoillumination.com like in the OP
VG33QX4
FYI
the 4wd switch has 3 bulbs and they are small micro bulbs regular filament bulbs and the cig lighter is a 74
Innovazn
VG33QX4 wrote:FYI
those bulbs are so small and its a TIGHT squeeze... be very careful... i got 2 in and the last one snapped inside i gave up.. it still looks good though.
accurate
Car: 02 Nissan Pathfinder LE
Help! I tried to put led lights on my cluster with no successed even try rotate the socket (WITH the bulb in it) 180 degrees and then re-installed. So, I giveup and put original bulb back, guess what, NO illuminate :confused: :ohno: !!! (the lights work before I did the changed) Can't figure out what did I do wrong? Any help with be greatly appreciate...
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
Check the fuses, and play around with the bulbs twisting them different ways, also put the stock ones back in if you dont get illumination,
This happened to me when i was adding the last odometer bulb ( i only put the 2 in for all the gauges and did'nt have a 3rd one so i needed to order it ). And i sat there at least 45 mins fiddling with it, just cause those small bulbs are a pain in the a**, but it takes some time and should work.
accurate
Thanks for the help! I did put the 2 stock bulbs back with no illumination. Now the shifter and 4WD nob were out too :mad: !!! Where is the fuse for the lights?
accurate
Can anyone point me out, where is the fuse for shifter and 4WD knob light :frown: ?
slickroger
accurate wrote:Can anyone point me out, where is the fuse for shifter and 4WD knob light :frown: ?
The dash lights should be the tail lamp fuse.
Try that
Towncivilian
My shifter LED bulb started flickering. I replaced it with a WLED-CW6 bulb and it is even brighter now. Also put in a high power LED in the glove box (dunno whether the picture above is normal or HP). I will get pictures for you guys soon.
Also, not pictured is the fact that the SES light is always supplied with power - enough that it is dimly, but visibly lit at night (with either a normal or high power LED). Here is a terrible iPhone picture:
Due to this, I will swap it out with a #74 incandescent bulb to avoid this annoyance. Since I always turn the car to the "ON" position before starting, I'll know if the bulb burns out again. I don't know where I'll stick the red high power #74 LED bulb now. I might see how it looks in one of the gauge illumination spots, odometer, or maybe the "low fuel" indicator (but honestly, if I need a blinding idiot light to tell me to get gas, I should not be driving!). I will also see how a normal and high power white #74 LED looks in the odometer position - I have found the 3xHP bulb to be a bit too bright for my liking lately. If it lights evenly and still provides easy readability, I'll throw up a picture of that too.
