The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Tue Apr 16, 2013 3:53 am
Your PMs are disabled (either by your profile or your number of posts). That said, since it isn't incredibly private anyway, you were checking with me to see if I had a link to the squeaky mirror issue or knew which dealers would fix it. My response:
Sorry, I don't have a link. I would have posted it as I did, but I can certainly imagine some people suggesting searching first just to make a point. Unfortunately, I don't have any idea on which dealers, either. I think they used to replace the mirror on warranty and then started rebuilding it, but I don't know for sure if that is correct or if they still rebuild them. IIRC, I assumed you were out of warranty when I made my post, so I thought you might want to obtain the rebuild kit yourself. If you have warranty, I'd suggest trying your dealer first and going from there, but even then, if you can successfully find the thread I'm talking about, having documentation to back your claim up might be helpful. That having been said, the thread was definitely on this forum, and it may have been about rattling/buzzing in the mirror, if that helps at all (I assume the fix would be the same, loose parts with inadequate insulation/padding can certainly squeak, rattle, or buzz when rubbing together).
