everettc1 »
https://forums.nicoclub.com/everettc1-u2783.html
Thu Jan 23, 2003 1:47 pm
Just had my S14 aligned today, but they tell me it's pulling to the right because of the caster, which is non-adjustable. The print out shows caster of 5.3 degrees in both front wheels, versus recommended spec of 6.0 to 7.5. Am I correct in assuming that caster measures how far forwards or backwards the wheel is, and that wrong caster will cause the car to pull to the left or right but won't cause the tire to wear wrong (unlike camber problems)? Also, Am I correct in assuming I have to check out the front tie rods and the frame, to see what's causing the caster problem?
Thanks,Wayne C.
