humuju »
https://forums.nicoclub.com/humuju-u202531.html
Tue Aug 06, 2013 8:53 am
Thanks for the responses. I did pour buckets for water with a lot of soap and some vinegar over the seat. The first time I did try it by pouring it on the bottom part. However, the liquid did not easily penetrate. I then poured it from the top, i.e. the leather and massaged it in. That eventually also made the water penetrate the underside. Then I used a lot of plain water to get the soap out and repeated this one more time. Then I squeezed as much of the water out as I could and tried with a towel. It's a lot of work and I still have it out drying.
As for the carpet, steaming it only helps for the top. As it turns out there were puddles of milk under the carpet. I think it came from the backseat and then towards the left door and still under the seat did go down under the carpet. The carpet also has a foam which got partly soaked. I removed all that foam and started cleaning the underside of the carpet pouring the same liquid as with the seat onto the carpet and then always get the liquid out before it got too high inside the car to reach further to the front. I did this a few times. The odor is much less now but it still stinks. I will have to repeat all of this again.
It's a real pain doing this. People say not to cry over spilled milk but one could be excused for doing so... Well, the lessen learned it that I won't ever have any liquids inside my car anymore except for plain water. And for the trunk I will think of some kind of container.
