qwertyz wrote:didnt i say check for spark at the end of the wires where the wire goes in to the spark plug?????
Yes, thank you for your advice. Was a nice spark. Cleared fuel from the engine. Installed new distributor cap today, and combined with the new ignition coil, the engine sounded better and better.
So, it's running now, though it was about to die when it started so I gave it a little gas. Maybe that's because I had cleared the lines by cranking it with the fuel pump off. I'll let it run for a bit then turn it off and try again.
Thanks again to everyone for their advice and help. I really learned a lot about troubleshooting this car!
Edit: Ok, let it ran for a bit and turned it off and it started back up just like new. *Whew*! So, bad spark from ignition coil and deteriorated distributor cap points appear to be the main culprits here. The dist points were eroded away a little bit, so I guess when I came home one day, one of the points dissolved a little too much so it didn't start the next day. Anyways, let that be a lesson to anyone who hasn't checked under their distributor cap recently!
