brokeAs240sx wrote:Have you had your alignment checked? what are the specs?
tried rotating tires to see if it changes at all?
does just the steering wheel shake? or does the entire front end of the car shake?
check the wheel hubs/bearings for play?
Yes I have had the alignment done. I don't have the specs, I threw the paper away. But I have had it done twice now.
Its not the tires, I just bought another set. This problem has been going on for a long time regardless of what tires I have.
Both steering wheel and front end shake.
how do i check the wheel hubs/bearings for play?
dkdeleon68 wrote:Have you checked your brake calipers? The piston in one of the calipers could be sticking or the piston boot is leaking. or it could be bad struts.
Replaced one brake caliper becuase it was leaking, the other one is fine. Neither sticks.
I'm pretty sure its not the struts. I replaced them a while back. Although I do need to replace them again, I'm sure that it wouldn't allow for the amount of shaking im getting. Going to upgrade to coilovers soon so I'll see what difference that makes, still pretty sure thats not it though.
ZiG wrote: As for the steering rack.. maybe you need to find a new mechanic.
I work on my car. Steering rack isn't hard to replace.
