Armstec_S13 »
https://forums.nicoclub.com/armstec-s13-u52419.html
Tue Jan 03, 2012 4:20 pm
Do you have an aftermarket alarm? Also did you check under the hood for the "eng cont" fuse? A couple of my friends blew that fuse including myself when I jumped my battery, would crank crank cram but no start, checked the fuses under the dash and nothing checked under the hood and found out that the "eng cont" fuse was blown, replaced it and started right up, hopefully this helps you and the simple fuse is the problem
