zna »
https://forums.nicoclub.com/zna-u220711.html
Wed Mar 05, 2014 10:47 pm
Hey everyone, Ive just finished putting my new timing belt on (120,000 mile service). When I try to hand turn the crank 360 degrees it stops as if its blocked my something (both directions). All the marks are lined up on the 4 cams and the crank. The timing belt didnt break, it was running fine when i decided to take it apart. When i removed the timing belt, some of the cams moved, not too violently, and the crank moved maybe 30 degrees from tdc. Any ideas on what it could be?
Just in case you need the info its a 1990 z32, na, manual.
Thanks in advance!
