Shocks, springs, sway bars, coliovers, bushings, brakes, rims, tires - You name it, this is the spot to discuss Versa suspension components and modifications!
Can the Nissan Versa pull a motorcycle trailer?
Postby PAINTER78 » Wed Jan 13, 2010 5:40 pm
I would like to get an enclosed motorcycle trailer since I am going to move to an apartment complex. Can a 09 Nissan Versa 1.8 pull a 2500 lbs trailer without causing damage or eccesive wear to any components? And if it can, is there a trailer hitch for it out there?
Tom
PAINTER78
Re: Can the Nissan Versa pull a motorcycle trailer? (PAINTER78)
Postby Promise Land » Thu Jan 14, 2010 3:46 am
There is a hitch out there for the Versa. I don't know the towing capacity from memory. Try NissanUSA's website and see if it's listed there.
Project: MEEP:
Versaspeed Grille
Tiida Xenon HID Projector Headlamps
APR Carbon Fiber Splitter
Custom Lower Mesh Grille
Earl's Stainless Steel Brake Lines
Tanabe NF210 Lowering Springs
Satin Black Spec-V Wheels
35% Tint
NISMO Graphics Kit
Promise Land
Car: 2009 Nissan Versa S 1.8L H/B
Postby V-Man » Thu Jan 14, 2010 3:41 pm
I doubt if the Versa can tow anything more than 1,000 pounds. The trailer alone probably weights close to that. I wouldn't do it. This is not an engine made to pull such a heavy load, plus the brakes will be used to their limits. Can it do it? Probably. Could it damage the engine or transmission? You bet.
V-Man
Postby Codelicious » Thu Jan 14, 2010 9:27 pm
PAINTER78 wrote:I would like to get an enclosed motorcycle trailer since I am going to move to an apartment complex. Can a 09 Nissan Versa 1.8 pull a 2500 lbs trailer without causing damage or eccesive wear to any components? And if it can, is there a trailer hitch for it out there?
Tom
My guess is that it could probably tow it.. but the car isn't built to do so, so I'm guessing that it could cause problems in the long run. I either wouldn't do it or I would go to my local Nissan dealership and get some information from them...
Project: Dark Knight
Car Domain: http://www.cardomain.com/ride/3827990
Codelicious
Car: 2008 Nissan Versa 1.8 SL
Postby Codelicious » Sun Jan 17, 2010 6:47 pm
Tom
Ok so yesterday I was looking through the FSM for something any it says, "Do not tow anything." If you want to look it up it is almost at the bottom of the FSM. Just view the PDF and use the Find toolbar and type "Tow" or "Towing" into it.
Codelicious
Re: Can the Nissan Versa pull a motorcycle trailer? (Codelicious)
Postby superskunk » Sun Jan 24, 2010 9:37 am
my friend tows almost 1500 lbs. with his 1.6 sedan.... he has stock shocks and eibach lowering springs...
superskunk
Car: '07 Super Black Versa S Hatch,'06 Super Black Murano SL
Return to Versa Suspension, Brakes, Rims and Tires
