The web's first forum dedicated to Nissan's groundbreaking electric car, the Nissan Leaf.
Can the leaf charge while driving?
Postby gwoods » Tue Apr 20, 2010 3:37 pm
I am looking at this car thinking what would I hate about it?
I don't like the idea of being stranded if I completely deplete the battery. I don't like the idea of having to wait for it to charge while being stranded.
I can think of a couple solutions. Solar panels on the roof could be charging the battery during the day but would they be able to charge it while I am driving?
What if I wanted to drive farther then 100 miles without stopping? Could I rig up a diesel generator to charge it as I drive?
Although my questions seem crazy they are serious questions
"only an idiot would trust North Korea" Condoleezza Rice 12/19/08
gwoods
Car: 2007 Infiniti G35 sedan
Re: Can the leaf charge while driving?
Postby relytgerg » Tue Apr 20, 2010 3:58 pm
"Can the leaf charge while driving?"
I don't know if the LEAF can charge while driving, but if it could, you would probably have to do some rewiring since the charging ports are on the front.
Some who have converted cars to electric have this capability and can tow a generator (or put it in their pickup bed) and run the generator to charge the car while driving, giving them extended range. I suggest you post your question to the Nissan Leaf live chat on the main page: http://www.nissanusa.com/leaf-electric-car
Your other option is the Chevy Volt which will be released about the same time as the LEAF, but comes with a built in "range extender" gas engine generator. This is a true electric vehicle, but tackles extended range with this approach. This will sell for more than the LEAF, but might be a preferable option for many.
relytgerg
Postby earth4ever » Wed Apr 21, 2010 12:07 am
I'm pretty sure Nissan would have to make some software changes to allow it. Their 120V and 240V charging uses the new J1772 connector which is now the standard for EVs. That is a "smart" connector rather than a simple plug, which has five terminals altogether, and includes a communication protocol whereby electronics in the car works together with electronics on the other end of the charging cord to make sure that there is no chance of a short or a shock. One of the features is that the car is supposed to keep you from accidentally driving away while you are still plugged in. ... I think you can see where this is going.
Incidentally, you can forget about running from solar panels built into the car. There's not enough surface area on the car to generate more than a trickle of electricity. If you covered the car with solar panels you might be able to get 40 watts at high noon, tapering to zero, of course, from sunup and to sundown. So figure an average of 20 watts times 12 hours on a sunny day. That's 0.24 kWh for the whole day, which is enough to go a little more than a mile. The designers would have to work pretty hard to keep from losing that mile through the solar panels' effect on the car's coefficient of drag.
The SL model of the LEAF does have a spoiler with a solar panel on it, but I believe it is only used to run a fan to keep the car a bit cooler when parked in the sun.
earth4ever
Postby Promise Land » Wed Apr 21, 2010 10:39 am
It's not a "zero emission" vehicle if it has a gas engine to produce electricity. that's more of a hybrid then, so just go buy an Altima hybrid.
Remember what the leaf is designed for, metro commuters that travel less than 100 miles per day. There won't be any infrastructure on the open highways to really plug the car and charge it. I don't know if you could charge it from an extension cord from a hotel room either (I've never looked into it).
Promise Land
Car: 2011 Nissan Versa,
1995 Nissan 240sx
Postby earth4ever » Wed Apr 21, 2010 6:59 pm
I'm afraid I have to disagree partially with you, "Promise Land". True about zero emission, but there is a big difference between a hybrid like the Altima which has to have the gasoline engine running most of the time, and the concept gwoods is aiming for, more of an emergency generator. As relygerg indicated, the Chevy Volt might better fit gwoods needs. But people have also long talked about the possibility of pulling a genset trailer behind an EV, only for long trips.
I also don't think you are being fair to Nissan's vision here. They are working hard to get recharging infrastructure in place, starting first in their initial target regions. Why do you think every LEAF sold will have a special 440V DC quick charge connector for an external charger when you can't even get one for your garage? Answer: Because there WILL be on-road infrastructure for recharging in 30 minutes or so.
Finally, yes, you could charge using an extension from a motel room, if the motel didn't mind, and you were willing to live with a partial charge or stick around for 16 hours. Much more likely, though, would be to recharge at an RV park while staying overnight in one of the cabins that many of them provide. RV parks often supply 50 amp 240 volt service, and although Nissan and the electrical codes wouldn't like it, you could put together something that would let you charge completely from that in about eight hours. I wouldn't be surprised if some parks start putting in approved 240 volt EV charging adapters, now that there is a single standard for them.
earth4ever
Postby CRyan » Wed Jun 02, 2010 12:35 pm
Just out of curiosity, why can't the wheels actually turning underneath the car be used to essentially "charge" the batteries? It would make sense, and seem to me as it would then never die. Just a thought, or in the case it has already been discussed, refresh me :)
CRyan
Car: 1997 Nissan 240SX
Postby relytgerg » Wed Jun 09, 2010 2:38 pm
The wheels do recharge the battery. When slowing, regenerative braking is used to recharge the battery. When cruising or accelerating however, the wheels are not regenerating power, they are using it. You can't get more more power than you use, so it makes no sense to try to use power and generate it at the same time. If this were possible, we'd all already be driving perpetual motion machines.
relytgerg
Postby CRyan » Wed Jun 09, 2010 3:42 pm
Thank you for the insight! I see now where it wouldn't make sense - But I figured I'd bring it up, anyway.
CRyan
Postby Queensbridge » Mon Jun 21, 2010 7:31 am
I doubt it. Charging only when stationary/parked.
Queensbridge
Postby float_6969 » Mon Jul 05, 2010 8:30 pm
As others have said, the aim of the LEAF right now is for those commuting less than 100mi/day, and you would have to re-write the software to allow it to charge while in motion, which wouldn't be an easy task.
Buh-Gawk! That's all the warning you're gonna get...
float_6969
Car: 1995 Nissan 240sx
Postby DDS » Thu Jul 22, 2010 7:46 pm
The leaf will be a Hybrid, an EH or electrical hybrid. The motors will act as generators to replenish the batteries during deceleration - just as every other gas Hybrid does. This function of the Leaf will extend it's range in the exact proportion as does any gas Hybrid, it is not an insignificant addition. Just like the gas Hybrids this recharging will only be a factor in city driving, it will have almost no benefit on the open road.
DDS
Postby WDRacing » Wed Sep 15, 2010 5:34 am
You could keep a Honda generator in the trunk for longer trips? Sounds retarded, but they come is really small sizes...I like to think outside the box.
WDRacing
Car: 1995 240SX, 99 540i
Postby huiru » Sun Sep 26, 2010 1:23 am
huiru
Postby LeafTalk UK » Mon Nov 08, 2010 4:48 am
Inductive charging is the future. If this technology gets off the ground we should be able to charge all our EVs whilst driving.
Check out the video:
LeafTalk UK
Car: Nissan Leaf on Order
Postby LEAFguy » Sat Nov 20, 2010 9:04 pm
In a word - No. The only in-motion charging will come from the regenerative braking system. You will not be able to rig a generator to charge while the LEAF is in motion.
LEAFguy
Postby JohnEvers » Tue Jan 04, 2011 9:27 pm
To add my two cents worth to this discussion, reading through the specs, I believe there is not only regenerative braking to charge, but also coast charging. This would allow some state of charge to occur when coasting when driving without applying the brakes such as slowing with traffic of going down hills.
JohnEvers
Car: Nissan Rogue
Postby themadscientist » Wed Jan 19, 2011 2:01 am
Yes, this is part of the system. it should feel like engine braking in an ICE vehicle.
I drink, your, MILKSHAKE!!!!!
themadscientist
Car: DR30 Skyline, 180SX, Daihatsu Hijet, NSR50
Postby DDS » Mon Apr 11, 2011 12:02 pm
I am under the understanding that "coast charging" is insignificant. One of the many methods the EV and Hybrid cars use to maximize mileage is to allow unrestricted coasting. I understand the computer program does recognize some situations when regenerative braking is activated for deceleration, but I was under the opinion it was a very minor part.
At least some of the Toyota hybrid cars have a new "B" position on the transmission shifter to allow for manual shifting into "B" for the very purpose of introducing some drag. Like what is always apart of a standard internal combustion engine automobile that everyone takes for granted. However the "B" is only partially regenerative - the major portion of the drag is friction braking.
Does anyone know if my comments are incorrect, or partly incorrect?
DDS
Postby themadscientist » Tue Apr 12, 2011 4:44 am
Regarding EVs in general, coasting is a way to save charge. Regenerative braking creates drag and slows the vehicle. While this is an advantageous use of deceleration to provide some recharge in a braking situation, in a cruising situation it would cost more charge to regain lost momentum than would be generated.
themadscientist
Postby kerrton » Wed Aug 31, 2011 8:02 am
Tons of good info here....really good discussion.
kerrton
Car: 2008 Nissan Rogue, SL FWD, Gotham Gray
Postby petnieto » Sat Nov 05, 2011 10:02 am
It is possible. Studies about smart superhighways are already underway that can actually turn this from concept to reality; imagine driving the Leaf on special ev charging lanes on the interstate which have embedded induction coils to charge the batteries without stopping!
petnieto
Car: 1997 Pathfinder 4WD
Postby 300ZXttZMAN » Tue Nov 08, 2011 11:54 am
petnieto wrote:It is possible. Studies about smart superhighways are already underway that can actually turn this from concept to reality; imagine driving the Leaf on special ev charging lanes on the interstate which have embedded induction coils to charge the batteries without stopping!
Who would fund it though.
Z32's are like water
We just cant live with out them
CLICK HERE to see my Z32 (300ZX) Twin Turbo build thread GO BROKE or GO HOME
300ZXttZMAN
Car: 1990 300zx twin turbo 5 spd pearl white
1993 S13 hatch (Soon to be NICO club drift car)
My Daily: 2000 GMC Sierra Z71 4.8L (Alot of mods)
Postby nissangirl74 » Tue Dec 06, 2011 5:52 pm
DDS wrote:I am under the understanding that "coast charging" is insignificant. One of the many methods the EV and Hybrid cars use to maximize mileage is to allow unrestricted coasting. I understand the computer program does recognize some situations when regenerative braking is activated for deceleration, but I was under the opinion it was a very minor part.
Coast charging can be quite significant. I have, however, found that while it does help recharge your battery, it significantly reduces the fuel-efficiency of a hybrid. If the battery on my Insight is in good shape, I will do my best to preserve fuel economy and let the car roll to a stop in neutral.
nissangirl74
Car: '00 Honda Insight, '05 Frontier, '79 620, '72 240Z w/RB25, '68 510, '67 WRL411, '67.5 SPL 311, '64
Bluebird, '63 NL320, '31 Model A
Postby BadQ45t » Mon Dec 12, 2011 5:21 pm
I have owned a Leaf now for a week and driven it about 200 miles. What I can tell you is that when I go down a significant hill the car does recharge itself, but just coasting on a flat road is essentially battery neutral. You can tell from the power meter on the dash board. I have a pretty good 2k drop I go down daily and I gain at least 4-5 additional range when I hit the bottom and the charging dots are all over on the left side.
As for charging while driving, that is called the Chevy Volt.
Jeff from Half Moon Bay
BadQ45t
Car: 11' Leaf (Wife's Car)
05' X-Terra
97' Q45t
84 300ZX (Original Owner)
Postby PapaSmurf2k3 » Sat Dec 31, 2011 8:42 am
I wouldn't be surprised if Nissan came out with a "charge while you drive" kit once they stop selling every Leaf they make (essentially, when Smyrna tools up and mass-produces). Right now they really don't have any incentive.
...generators typically fall under a different classification for emissions too. Being that most leaf owners are all sorts of green, they might not be too keen on hearing about the non-catalyzed exhaust pumping away.
You'd need a pretty substantial generator to keep the thing going indefinitely too... somewhere in the neighborhood of 20 kilowatts if my math is correct. That equates out to about a 27 hp generator.
PapaSmurf2k3
Car: 1991 240sx KA-T, 1997 Prelude, 2001 Miata turbo
Postby BadQ45t » Wed Jan 11, 2012 10:26 pm
There is simply no place to put it. this car is a commuter car and the really big promise will be for the fast chargers that can get you back up and running in 30 minutes. The Volt is the platform if you need to recharge while you drive.
BadQ45t
05' X-Terra
97' Q45t
Postby PapaSmurf2k3 » Thu Jan 12, 2012 4:16 pm
Word has it Infiniti will be coming out with an extended range electric vehicle (much like the Volt) based on the leaf. Makes sense that it will be Infiniti when you think about the price it will have to be.
PapaSmurf2k3
Postby BadQ45t » Thu Jan 26, 2012 11:15 pm
That makes sense, more upscale to compete against the Leaf, would be a wise use of the electrical power they created for the Leaf. If they had a Volt-style Infinti with say a 120 KW engine (Leaf is 80) and give it a 100 mile range on electric, and styling and interior more on the side of the M then then G, I would buy that car in a heartbeat and install my in-door charger :)
They should build that car, but not the 30-35 miles range the Volt has, for me that makes no sense. 100 miles like the Leaf, 20% faster/quicker, I'll take one.
BadQ45t
05' X-Terra
97' Q45t
Postby rogUK » Sat Mar 24, 2012 10:47 pm
I was thinking for a long trip I could put 10 100AH 12V lead acid batteries in the boot and run a static inverter to power the 2.5kW charge socket, put the cable through the window. On the 4 hour journey from where I live to London this would give me an extra 10kWh. The extra weight would impact on range but I'd be hoping it might get me to the 140 mile range I'd need on a very careful 38 mph drive. I'd estimate the lead acid would last about 200 cycles, which on 1 journey per week at cost say £1000, last 2 years and work out at £10 per week. The quetion is, how easy would it be to get the car to drive while the charge port was active? Has anyone evr tried asking Nissan for this kind of special software help? Are they at all responsive?
rogUK
Car: nissan leaf
Return to Leaf Forum
