maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Wed Mar 04, 2009 8:33 pm
A better question is, "Which 22" tires will provide sufficient OEM minimum load capacity (94) and still be the OEM diameter (26.1").
For a Michelin PS2:
255/30ZR22 Load Index 95 = 1521lbs (690kg) per tireSpeed Rating “(Y)” = 186+mph (300kph) (95Y) XL
And only $426 each before mounting. There are some cheap azz Kumhos available though for less.
However, the unloaded rolling is 28.1", which is a big problem.
Suppose you jack your suspension enough to fit them without any ill effects, the next question is, "Which wheels do I get that are near the OEM 2..5 lbs. but strong enough to fit on the FGY33?"
I'll let you figure that one out, but even the best forged (BBS, Fikse, OZ Racing) won't come near that weight. This will run you about $4K new. Of course there is cheaper and much heavier and weaker trash rotary anchors out there.
So for about $6K exclusive of labor you have worsened your ride quality, increased you braking distance, diminished your cornering performance, and shortened the life of your suspension components.
Fair trade off, no? Sure looks kewl parked there at the Sonic service island.
I have to wonder the load rating of the 20" tires you are presently using? Only one size barely ekes past the minimum.
