Can I fit 20x10 offset 40 wheels to EX35?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
newexowner
Car: EX35
Hello,
newexowner here. I'm looking to purchase a new wheels for my EX, and trying to see if anyone running 20x10 with 40 offset. I'm planning to run 265/35/20 tires on them. Would I have any rubbing issue? I'm on stock suspension.
Thank you.
bigbenex35
Car: Ex35
It will fit... no problem at all.
I have 20X10 +25 on 255/35/20 with G35 eibach springs and no rubbing at all.
Infiniti4infiniti
Car: EX35/G37S Sedan
do you have more pictures of your 20X10 set up??? thanks so much
Dmas
Car: 2008 Infiniti EX35 RWD Journey
2001 BMW Dinan M3 Vert
I bought my EX35 back in June and just put coilovers and wheels on it. Wheel specs are 20x9 +35 with 245/40 (fronts) and 20x10.5 +40 with 275/35 (rears). I had to trim and roll my fenders but it doesn't rub now unless I hit a big bump and then it will barely rub the inside fender liner.
Infiniti4infiniti
do you have a couple more pics of your setup? i have 20x9's et38 on 255/40's and am perfectly flush with fenders. i want to run a 20x9.5 et44 (puts me flush still)with 255/40 tires. i know the wheels will fit. how will the extra 1/2 inch of wheel width affect the lateral handling of the tires?
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
