Camshaft sensor P0340
jsudaria
Car: 2003 Infiniti M45
2003 infiniti M45. About 10 months ago, I had a code P0340. So I had the camshaft sensor replaced. A few days ago my car started idling very rough for about 20 seconds every time I start it. My car has stalled on me a couple times and turned off completely while I was driving. The service engine light came on and the screen said VDC control warning and the dashboard said VDC off. I checked for a code and the P0340 is back again. Any ideas??
Thanks,
Jason.
EniGmA1987
Car: '06 Infiniti M35 Sport
IDK about the 03 M45's, but the newer models with the V6 have 2 camshaft sensors and 1 crankshaft sensor. One of my sensors went out one year and then about a year later the other one died too.
BlackCat81
Car: 2006 M35x
2003 Lexus GX470
Check to see if it's low on oil.
Wangtang408
Car: 2006 M35
BlackCat81 wrote:Check to see if it's low on oil.
I lagged in my oil changed and the code popped up for camshaft sensor, I got the oil change at the dealer and my buddy at Autozone checked and clear the code for me.
Should I still proceed with the camshaft sensor replacement?
If so, should I go ahead and replace the crankshaft sensor as well?
And lastly would any after market sensors do like eBay or should I get OEM from dealer?
BlackCat81
Car: 2006 M35x
2003 Lexus GX470
If the light stays off don't worry about it.
Wangtang408
Car: 2006 M35
And lastly would any after market sensors do like eBay or should I get OEM from dealer?[/quote]
If the light stays off don't worry about it.[/quote]
Cool, appreciate your feedback.
I was told that the light came up because of dirty oil.
DeanM45
Car: 2006 Infiniti M45 Sport 1 or 2 mods
jsudaria wrote:2003 infiniti M45. About 10 months ago, I had a code P0340. So I had the camshaft sensor replaced. A few days ago my car started idling very rough for about 20 seconds every time I start it. My car has stalled on me a couple times and turned off completely while I was driving. The service engine light came on and the screen said VDC control warning and the dashboard said VDC off. I checked for a code and the P0340 is back again. Any ideas??
Thanks,
Jason.
This info pertains to the M45 only as I have not dealt with the M35's.
The camshaft sensor should only be replaced with dealer parts. Easy replacement, driver's side, front of engine.
There are also two other "camshaft sensors" (they are camshaft timing sensors for the variable intake timing) located on top, in the front of the motor but those throw P1140 and P1145 codes if bad). These two sensors are interchangeable with each other.
There is a revised CRANKshaft and CAMshaft sensor by Hitachi (now looks like a metal cylinder instead of the rectangular plastic). The CRANKshaft sensor is on the passenger side, at the bell housing. The CAMshaft sensor, as mentioned, is on the front of the motor, driver's side about the same level as the water pump. These two sensors (CRANK and CAM) are also interchangeable with each other.
Make sure your oil is clean and full and erase the code. Start the car and run for 10 seconds. Turn off for at least 10 seconds. Restart and run for 10 seconds. If no code then don't worry about it. If the code comes back, replace the sensor. It IS a simple DIY job. One 10mm bolt holds the sensor on.
Wangtang408
Car: 2006 M35
Thanks Dean, I looked up in the FaQ but looks like there is no write up for it.
I founf some vids on YouTube, looks pretty easy.
Btw my code was P0011
DeanM45
P0011 is NOT a sensor code -- it is a code for the solenoid that controls the intake cam timing. There are two of them on the 35, one on each bank. Around $120 for the solenoid. I think 4 bolts hold it on. There is a metal gasket that it uses, do NOT use RTV there.
Wangtang408
Car: 2006 M35
The light has not came back, should I leave it alone or replace the solenoids?
DeanM45
Wangtang408 wrote:The light has not came back, should I leave it alone or replace the solenoids?
Don't worry about it unless the code comes back.
Wangtang408
Car: 2006 M35
Thanks Dean!
