Relax! we are here to help or next time we might just tell you to usez33nismo12 wrote:im talking about the rear, and you dont have a link!
Toe control rods are not made to adjust camber and camber arms are not made to adjust toe. Two separate adjustments are needed. You make a rather silly argument against the people designing Stillen's toe control rods considering you apperar to have no idea what you're talking about.JETPILOT wrote:Those stillen "toe rods" are worthless. You can't adjust camber correctly from that position. I don't know who invented those, but they had no idea what they were doing.
Riiiight. I'd rather you bring forth your technical knowledge than try to boast about your "experience". It would show a lot more of what you claim to know than simply claiming to know...JETPILOT wrote:I hope your not refering to me as "not knowing what I'm talking about". I have more experience in 350Z suspension than anyone two people you choose to name combined.
Changing the length of an arm or using an eccentric bolt will both change suspension geometry. An eccentric bolt works by moving the pivot point of an arm. So it also changes the suspension's geometry. There is always some level of compromise with any solution. Especially with a lowered car as the rates the wheel angles change will differ than it would at stock height. But, if you feel that the eccentric bolt on the LCA is the better option, please share your observations.JETPILOT wrote:The only correct point to change the toe on the car is along the axis of the lower control arm and NOT the traction arm. Toe CANNOT be adjusted corrctly from that point. It will throw off the suspension geometry.
I most certainly do know which arm the Stillen toe adjuster replaces. However, I'll admit that my initial thought was that the eccentric bolts were going to be used on the radius arms (the photo isn't too clear on the site you linked). Be that as it may, the toe rods do effectively change toe. And considering that the radius arm is a big reason for a change in toe in the first place, it certainly makes sense to try and adjust it from there. In any case, changing the pivot point of the LCA or the length of the radius arm both present its own set of issues. I'd speculate, the most die hard suspension tuners would prefer to have the ability to adjust every link in some form or other. Perhaps pultiple adjustments. But that would likely be overkill for most people...JETPILOT wrote:From reading your explanation I don't think you have a real grasp of the rod he wants to replace with this sham of a "toe rod".
Right, but changing the length of the"camber arm" does as well since the radius arm would follow an arc that pushes the spindle back as the camber arm is pulled in.JETPILOT wrote:The “toe rods” (radius rods) that are sold to adjust toe do adjust toe, but they do not do so independently of adjusting caster.
As far as I can tell, none of the lower suspension arms would isolate any one critical alignment angle as none of them are on any of the planes of a critical angle. Even the LCA would cause some change in camber (perhaps negligible, but still there).JETPILOT wrote:Toe was designed to be adjusted form the lower control arm eccentric bolts. If you adjust this bolt you adjust toe only.
Frankly, lowering the car in that of itself tends to throw alot of things off. Namely the rates of dynamic alignment changes that are designed to create a specific handling trait. Depending on your goals, this could be good or bad. I agree that trying to isolate toe is a good thing, but already having lowered it, it may have negatively affected the dynamic camber and dynamic toe rates of change. Then again, it could have had some positive effects.JETPILOT wrote:If you attempt to adjust toe from an adjustable length radius rod you will simply throw the toe off and possibly out of range of what can be recovered through the eccentric toe bolt. If your caster is withing OEm spec then there is no reason to adjust the length of the radius rod to adjust toe when the factory put in a toe adjustment point.
I don't call any options ideal. Short of being able to adjust everything, including mounting locations for the suspension arms, everything involves some level of compromise. Even factory adjustments.JETPILOT wrote:So install the adjustable radius rod which is sold as a “toe rod” and enjoy screwing your caster to achieve the toe adjustments your after. Doesn’t make sense.
I think we can all appreciate the knowledge you're bringing to the table here, but ultimately, most people here are simply looking for an alignment fix. I'm not trying to say the eccentric bolt is a bad thing. As I said prior, my assumption was that the eccentric bolt was being used on the radius arm. In which case, it was just a comparison of eccentric bolt vs adjustable arm. The other point had much more to do with the mix up with words.JETPILOT wrote:I am no suspension genious but I have spent a lot of time underneath my car and I have run suspension simulations on the computer and watched the effect of different changes to toe, caster, and camber and this is what I learned.
Perhaps, but the OE also isn't going to have considered the effects of lowering a car in their design either. otherwise none of the companies out there would be creating such solutions.JETPILOT wrote:The SPC toe bolt and an elongated adjustment hole is the correct way to adjust toe just like the factory intended it to be.
i know toe wares tires. but unless you lower your car 3in+, the rear toe is not going to be that off.JETPILOT wrote:Your incorrect. Toe is the number one casue of worn tires. Even more than cmaber. If you lower your car your changing both the camber and toe. You need a way to get them back into spec unless you like replacing your tires and having strange handling issues. This is lowering 101. You don't wanrt to do it.... don't do it. It's not my car.
Camber arms and SPC toe bolts are the only correct way to do it.
I've been running around a 1.6 inch drop on just springs and shocks for a while now with no problems what-so-ever. Only thing is, i drive it about 50% track and despite the drop, i still dont have enough negative camber in the front. I have 245 40's in the front running at 46psi and i still *can't* keep my pilot sport 2's from wearing the sidewalls.RCAnismo wrote:I was looking at the Eibach 1in.lowering springs today. I do zero track days with my car and it would be strictly for street use. I was going to get these springs and some nice aftermarket shocks.
(In laymens terms) Am I safe just to buy these 2 items, take it to my local alignment shop and be done with it? It sounds like I'm opening myself up to a world of problems......
Please feel free to explain how I'm dancing around the issue...JETPILOT wrote:Your dancing around the issue.
All I am saying is the factory toe adjustment point doesn't appear to isolate the toe. In much the same way adjusting the camber arm doesn't isolate camber.JETPILOT wrote:If you want to correct toe the factory gave us a toe adjustment point. If you want to adjust camber the factory gave us a camber adjustment point. When you lower a car you need to adjust camber and toe to factory spec.
Why would you put in an adjustable radius arm to change caster to remedy toe and camber?
So how does this prove your point? Companies other than Stillen also use the radius arm to adjust toe as well.JETPILOT wrote:Here is a pic of the JUN time attack 350Z. Built from the frame up to be a race car. Do you see an adjustable radius rod in this picture? Nope! Do you see and adjustable lower control arm? The same position from where you adjust OEM toe? Yep!
Either you have the terminology or your understanding about rear toe mixed up.JETPILOT wrote:Toe being beneficial to handling is subjective. Sometimes you'd like to have positive toe in the rear on a tight course like an autocross for quick turn in. Sometimes you'd like to have negative toe for high speed stability on a fast road course, and some drivers like no toe like myself. To say it's beneficial or not depends on the circumstances.
I'm not sure what you're trying to say here. If you're not riding on your sidewalls, it sounds like you have enough negative camber...redsx13 wrote:I've been running around a 1.6 inch drop on just springs and shocks for a while now with no problems what-so-ever. Only thing is, i drive it about 50% track and despite the drop, i still dont have enough negative camber in the front. I have 245 40's in the front running at 46psi and i still keep my pilot sport 2's from wearing the sidewalls.
oops, sorry. i ment.... i still cant keep from wearing out my front tire's sidewalls.C-Kwik wrote:I'm not sure what you're trying to say here. If you're not riding on your sidewalls, it sounds like you have enough negative camber...
Is THAT the factory camber adjustment technique?TeflonG35 wrote:just be happy that your rod that controls camber isen't bent like this.
Thankyou C-KWIK,C-Kwik wrote:You might try other things first. Part of the roll onto your sidewall may be from overdriving. Go into a turn too hot and you'll understeer. Its hard to power out of understeer if it means you'll take a wider line than the track allows. Try braking a bit sooner and enter the turn more slowly. Then power out sooner taking a later apex. Also, try to use some trailbraking to bring the rear around initially. You can work up to this from a slower entry.
If driving technique can't overcome the issue, then you could try using stiffer sway bars to reduce body roll and perhaps tune for a bit more rear bias to help increase the rear slip angle (which will reduce load on the front tires). Adjusting static camber can help, but it will affect braking performance.
Thats what curbs do when you slide into them.. It hurts. I had to hack saw off the lateral arm because the car was sitting in a apartment complex parking lot. No way to get power tools there.C-Kwik wrote:
