Q45tech wrote:........The Heater core and evaporator are already very dirty and block much of fan air flow, so you would need to clean them FIRST before adding a filter to avoid self destruction of fan motor from too much back pressure of existing restrictions.........
Here's a good DIY tutorial from Q45.org on cleaning of the G50 evaporator. While you've got it apart remove the blower fan and clean the blades to help extend the life of the blower motor and fan control amplifier.
It took the Infiniti engineers 7 years but they did finally put a cabin filter in the 97 and newer Q's.
http://q45.org/cleanevap.html
