CA18DET ECU Tuning and FREE downloads!
pulsar gtr
Car: NISSAN VEHICLES
Hi Mods,
I have completed few ecu programs for different injectors and all set to work with a Z32 maf, but I would like some one to host them if possible. I haven't tested them in a real life senarios, so user use it at your own risk.
Here is a list of the tuned programs that I have made.
370cc with Z32maf440cc with Z32maf550cc with Z32maf650cc with Z32maf.
If some one can host them and make it a sticky that would be great.Please email me your at [email protected] so I can email you the bin files for the above programs.
Thank you,RafiPULSAR GTR
c-rad
Car: 1991 Nissan 240SX w/CA18DET
I can host them dude.... I am also hosting Live Edit so it works out well... My email is [email protected]
pulsar gtr
I have sent you an email with an attachment.Any one that has similar setup as the above and willing to try these file at their own risk, please give some feedback.
Thank you,
RafiPULSAR GTR
pulsar gtr
The files have the following changes done to them.K Value,TP valueBoost levelVQMapmax rpm set at 7700rpmMax speed 300km/hr
PUSLAR GTRRafi
Modified by pulsar gtr at 4:10 PM 11/6/2005
c-rad
Ok, I will whip up a web page tonight. I actually want to make a site specifically dedicated to ECU tuning on the CA.
capwred
when you get it done hit me up for i can look at it.
c-rad
Ok, its done... for the most part.
Here's what I did-I made a file management system. Basically it is divided into 2 categories. One category is for the Live Edit program and the other is for the ROM files. It also has the ability for people to upload their own .bin files and give a description of each one. This way here other people can submit their own tunes. It would be nice if people were to upload them, to give a list of their current mods so others can compare. Give me some feedback on it. I am going to make a main page with tips on tuning, what kind of stuff you should get, etc... Here's the address-
http://ca18det.escic.com
Enjoy!
pulsar gtr
Hi C-rad,
Thanks for hosting them man, I hope other members find them handy and if you or other members can try these files, that would be great.
Thanks,RafiPULSAR GTR
1SlowCA18DET
is there a site where i can learn how to read the tables?
pulsar gtr
lots of the stuff that I learned, I learned it from this website.
http://ecu2.forumwise.com/view...489f9
Good luck,RafiPULSAR GTR
float_6969
I'll email the other mods right now and see how they want to work this. It'll either be it's own sticky (we're trying to minimize the number of stickies) or one of the current stickies will have a link to this thread contained in it.
NeedCAforS13
Car: CA swapped S13 coupe
added it to the main sticky at the top of the page
Sean
pulsar gtr
Thanks Boys
PULSAR GTRRafi
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
ill try out the 370-z23, and 550-z32, but it will have to wait till i can get my good computer chipped, my chipped ecu started acting up this week and not giving me enough fuel, stock one works great though.
zero_gripS13
Car: soon to be 95 s14 hopefully
whats a good way to learn how to rom tune your own stuff??what do u need to write chips?
biosehnsucht
Error[DBIM] Query Failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '16", date = "1131479615", agreement_id = "", pass' at line 5 Query: INSERT INTO downloads_files SET category_id = "1", name = "CAMAF-dsm450cc-240kmh.bin", description_small = "CA MAF - 450cc injectors - speedlimit changed to 240km/h", description_big = "CA MAF - 450cc injectors - speedlimit changed to 240km/h\r\n\r\nDepending on your mods might run into boost cut at lower RPMs as I haven\'t yet gotten around to playing with that, this is the bin I (BioSehnsucht) am running in my ECU right now. \r\n\r\nSince I am running this so you can call it \", downloads = "", size = "16", date = "1131479615", agreement_id = "", password = "", status = 0, convert_newlines = 0
c-rad
biosehnsucht wrote:Error[DBIM] Query Failed: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '16", date = "1131479615", agreement_id = "", pass' at line 5 Query: INSERT INTO downloads_files SET category_id = "1", name = "CAMAF-dsm450cc-240kmh.bin", description_small = "CA MAF - 450cc injectors - speedlimit changed to 240km/h", description_big = "CA MAF - 450cc injectors - speedlimit changed to 240km/h\r\n\r\nDepending on your mods might run into boost cut at lower RPMs as I haven\'t yet gotten around to playing with that, this is the bin I (BioSehnsucht) am running in my ECU right now. \r\n\r\nSince I am running this so you can call it \", downloads = "", size = "16", date = "1131479615", agreement_id = "", password = "", status = 0, convert_newlines = 0
Try it again... I may have had some conflicting permissions...
JICdrifter
can someone burn me a rom for dsm450cc injectors, z32 MAF and 8000 rev limit
silviadrifta
Car: 1990 Nissan Silvia K's
zero_gripS13 wrote:whats a good way to learn how to rom tune your own stuff??what do u need to write chips?
would also like to know, i am a major newb when it comes to this stuff.also found this, dont know if it helps or not, http://www2.osk.3web.ne.jp/~t1....html
biosehnsucht
well as I was copy/pasting back in from my post I noticed that it cut my "long description" section off and thats probably where it got the syntax error in the error msg I posted, it cut off the end and didn't close the " for the data in that column, and screwed up the rest of the DB insert.
but I just now tried again and made sure it was shorter, got this: The file type you uploaded is not within the allowed extensions list. You may not upload this type of file.
the filename is CAMAF-dsm450cc-240kmh.bin so I'd hope you are allowing .bin :P
c-rad
DOH!!!!!!!!!! Try NOW!
Edub1
Car: 89 240sx KA-T
Damn, you guys got it licked. I wish we had guys like you in the 240sx community.
Anyway, what would it take to get you guys to help us out a little? All we seem to have are a bunch of deadbeats that tell us to search and figure it out ourselve's. Hell, the only thing I'll figure out is how much it will cost to rebiuld my motor when I blow it up.
What do you say guys, can you throw us a bone or two?
pulsar gtr
Hi Edub1,
What is a common setup for your KA engine, as I just got some bin files and address files for the KA engines sohc and dohc. I will try and setup up some tuned ecus, but I need to know what kind of injectors and setup is the most common.
On the other hand, have any one tried the above bins, and if so, any input will be great.
Cheers,RafiPULSAR GTR
Edub1
Car: 89 240sx KA-T
Dude, you rock!
Probably the most common setup would be 7 - 12lbs of boost, 460cc injectors and a Z32 MAF. What software do you use?
As for 180 tunes, our motors are 2.4L. I'd be leery of a tune based on a 1.8L
c-rad
Edub1 wrote:Dude, you rock!
We use the Live Edit program that is on that site above... if you have a KA24E, then all you need is to get your ECU socketed. If you have a DE, you will need a daughterboard. Go to http://www.bikirom.com and check out some of his boards.
Edub1
Car: 89 240sx KA-T
Does live edit work well? I keep getting some kind of 13 error and the program crashes untill I reinstall it. Why is this?
c-rad
Edub1 wrote:Does live edit work well? I keep getting some kind of 13 error and the program crashes untill I reinstall it. Why is this?
Works fine for me. Make sure you follow in the installation instructions precisely. It's finicky in that way. You MUST have it installed in the C:\ drive (the root of C drive).
originalsin
so which is better rom tuning or live edit? wats the diff? i want to get into tuning my own car, and am willing to purchase wat i need
c-rad
originalsin wrote:so which is better rom tuning or live edit? wats the diff? i want to get into tuning my own car, and am willing to purchase wat i need
Do you mean ROM Editor? If so, Live Edit is nice because you can use it in conjunction with the pocket romulator from xtronics (www.xtronics.com) and do some live tuning on the dyno or street (provided you have a wideband). Plus, Live Edit has a much nicer interface...at least to me.
originalsin
the pocket romulator thats like $180 right?? ok so it sounds liek ill try working with live edit. im on hybridka, searching and trying to figure out how to get live edit to install, i unzip it, and go to install and it says "invalid command-line arguments. Unable to continue." do u recomend picking up a cheap laptop for this? can i use a mac laptop? i have like 3 of those lol.
