Completed my first plenum pull yesterday! Everything went back together nice and smooth, fired her up, and she had a HUGE air leak somewhere at the back center of the engine that was eventually killing her at idle. My pipe that runs from the IACV to the Balance tube had a small crack in the end of it, so I initially thought it was that not getting a good seal, and for leaning over the running engine and listening, it sounded right, but I didn't feel any leak with my hand. Plus she was struggling at idle, which made sense with a bad IACV connection. Anyways, I put in an order for a replacement hose, and was happy to sit on it a couple of days until the hose arrived.
Last night, literally in the middle of the night, I woke up with an 'oh s***' moment. I did the EGR Bypass Without Removal
http://z32.wikispaces.com/EGR+Removal#P ... %20Removal where you cut back the EGR pipes to the plenum, and pull the solenoid and vac lines, but leave the valve in place. As I was happily removing everything, I pulled the EGR solenoid to hard pipe behind the plenum line, then the hardpipe to EGR Valve line. I didn't cap the vacuum connection to the EGR valve.
So, I'm wondering, am I allowing exhaust or something else to leak out of the EGR valve by not capping that vacuum connection? Am I going to have to dig my hand back there and try to find that stupid vac line connection to cap it off?
Not that I think it matters here, but list of work done: Plenum Coolant Line Bypass, EGR Bypass w/o Removal, AIV delete, Valve Cover gaskets redone, new injectors
